6085 contact service with battery 6085 water damaged set . Icleaned it & flashed it with 6.00 version write pm but it shows contact service with battery but normal mode is ok with ufs or jaf. what should i do now |
can make self test using UFS and post result! ---- Byte |
self test passed all test in ufs |
check your flash ic...try re hot it..mild... |
just write good pm br |
contact service with battery any java based bb5 phone. 1-check battery connector's bsi pin, 2-resold/reball retu, 3-change retu. post reply. good luck |
hi Quote:
u have given such a solution which even a starter can give please be specific bro as to change retu is not such an easy tasking |
changing of retu is easy job please try it. you shoud a little practice it. best of luck. |
hi sir 3110c keypad ic is ok but keypad not working |
sir plz give me solution urgent plz |
ur problem is not clear. write clearly. what happend in ur set. i mean all keypad not work? nor some work/ some not work? r u sure ur set's keypad ic ok? and how u sure the keypad ic ok? if not ok then change the keypad ic another set, not market ic.post result. B.R. |
contact service 6085 dear sir!!! plz could u help me plz? i have nokia 6085. "contact service" this is the log ; owering the phone... Reading... MCU SW version: V 06.00 28-11-07 RM-198 (c) Nokia. HW version: 1402 PCI version: RFIC version: 17211721 DSP version: pb06w14v50.1 PPM version: V 06.00 28-11-07 RM-198 (c) Nokia. C Retu version: 32 Tahvo version: 53 Content Pack version: Content: c V 06.00 28-11-07 RM-198 (c) Nokia. Production serial number: PMD608758 Product code: 0550853 Module code: Basic production code: 0531924 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 358630015167465 IMEI spare to net: 3A 85 36 00 51 61 47 06 IMEI SV to net: 33 85 36 00 51 61 47 26 F4 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-198.ini Saved INI not found, loading INI list... WARNING! Update your Pkey to increase life counter! Setting local mode... Reading product code... Product Code: 0550853 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\ Searching for default location of ini... Checking path: \Products\RM-198\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-198\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! thnx u to aswer me. |
brother tell me press power button show contact service? or startup without sim press ok show contact service? |
it shows contact service |
I have also this problem. The phone is working on UFS normal mode. But with battery is not working. Can any one give me the BSI track of 6085 |
