Old 09-10-2003, 12:34   #1 (permalink)
Member: 15772
Nokia 5210 freezing
On power on this Nokia displays the usual block screen then blank. the LEDs stay on but no keys work.Cannot even be switched off. Is this hardware or soft and how to repair??
rgds
Old 09-10-2003, 19:09   #2 (permalink)
legija
Guest
Posts: n/a
Member:
1.CS
2. CPU
3. COMBO FLASH
-1. It may be in "contact service" so, it's on good place i hope
You should check it on Wintesla, or eeprom tools, sou you get reason for CS if any.
-2. Badly soldered CPU/or bad CPU by it self.
-3. Same for combo flash.
Try writing good full backup fron working phone first.
Old 09-10-2003, 19:44   #3 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
maybe ~30 KHz crystal, if its damaged, phone freezes, or starts very slow (VERY)...
Old 09-11-2003, 06:14   #4 (permalink)
Member: 15772
tried but phone cannot connect by cable to computer to use wintesla or any other tools. Must be some hardware failure maybe??
Old 09-11-2003, 06:59   #5 (permalink)
Member: 23372
Thanks Meter: 18
maybe you had to change the cpu
Old 09-11-2003, 15:09   #6 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
Hi Xanga
in 5210 is always the CPU try joins, just put some flux around and reflow the CPU.. will works , i fixed them all the times..
cheers
Old 09-17-2003, 23:17   #7 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
yes reflow cpu and flash
Nokia 5210 Freezing Solution billycool77 Nokia Hardware & Hardware Repair 5 01-31-2006 16:35
5210 freezes after 5sec kharr Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-21-2003 22:26
5210 freezing in games menu joe locks Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 12-11-2002 16:40
nokia 5210 PPMs.. microera Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 03-21-2002 02:43
NOKIA 5210 NEED PARTIAL frog Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-26-2002 08:20
Page generated in 0.25248 seconds with 9 queries
