03-10-2006, 04:50 | #6 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Dublin Age: 44
Member: 100436 Status: Offline Thanks Meter: 57 | Quote:
What are "flat connections" ? BR | |
11-22-2006, 21:47 | #10 (permalink) |
Junior Member Join Date: Nov 2006
Member: 392048 Status: Offline Thanks Meter: 0 | i had the same problem with my girlfriend's phone (nokia 6101).. and yeap.. you guys were right.. it was the flex cable.. apparently it was a bit loose.. so no big harms.. i took apart the lower flip part (where the keypad is, from behind).. and i unhooked the flex cable and reflowed it.. and plugged it back.. and that was it.. the camera started to work again.. If anyone is not sure how to do this.. google for a full housing installation for this phone.. and you'll be able to take your 6101 apart.. And, if that doesnt fix your problem.. my guessing would be either you will have to check the upper flip part (to see if the camera is well connected) or get a new flex cable.. cheers |
09-09-2007, 14:28 | #13 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | need solution for non working camera on 6101. on both phones same problem , when i want to use camera phone says OPERATIO FAILED and then CAMERA ON STAND BUY . 1. it is not flat cable - i tried 2. it is not software problem - tried that too 3. it is not mask problem- i tried that becouse one time i change it completly and it worked and it still works please help any solution is neaded one more thing - these phones are almost new , no water. |
[Share here] Dynamic Camera Configuration / CAMERA ON STANDBY PATCH | bluffmaster | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 630 | 09-04-2012 08:12 |
Nokia 7250: Camera operation failed! Camera on standby | Syri | Nokia Hardware & Hardware Repair | 11 | 06-01-2011 19:09 |
5610 camera *CAMERA ON STANDBY* help! | khan6653 | Nokia Hardware & Hardware Repair | 5 | 07-06-2009 14:19 |
camera on standby 6280 says while operating camera | gsmservices | MT-BOX | 0 | 09-06-2006 16:41 |
6101 camara on standby | shruti | Nokia Hardware & Hardware Repair | 0 | 04-22-2006 03:02 |
