10-30-2011, 18:15 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Punjab, Pakistan Age: 38
Member: 264520 Status: Offline Thanks Meter: 61 | 6120c and 2700c full flash but UI failed... 6120c was in MMC fault...but show blinking fault when i check it after few days... try USB FLASH with MXkey and HWK and fbus flashing with HWK version 7.20v flashing done but failed in UI setting... 2nd 2700c it's also in blinkg fault... same i try USB FLASH with MXkey and HWK and fbus flashing with HWK final version 09.97 flashing done but failed in UI setting... when i open 2700c... i saw some area ( lcd connector and handsfrees jack) are water damaged with few drops of water...i clean pcb and try again to full flash and ui setting but attempt failed.... any idea??? Micro |
10-31-2011, 00:22 | #2 (permalink) |
Freak Poster Join Date: Feb 2009 Location: jl.delima no.17 panam
Member: 969971 Status: Offline Sonork: Vincent_Lim Thanks Meter: 294 | Download & extract it.. put in the file into mcu only, and do flashing.. http://www.4shared.com/file/eH1ZqBLU...KB_pmm_10.html |
10-31-2011, 12:01 | #4 (permalink) | |
Member: 264520 Status: Offline Thanks Meter: 61 | Quote:
wht's next?? and wht's solution for 2700c? remember... i've MXKey and HWK only... Micro | |
10-31-2011, 20:10 | #5 (permalink) | |
Member: 969971 Status: Offline Sonork: Vincent_Lim Thanks Meter: 294 | Quote:
try put 6120c eno file to mcu one by one.. then try flashing again... the eno file you can get it from your file flash.. for 2700c i got same problem n still waiting for solutions too.. i changed cpu n ic flash problem not solved.. | |
06-14-2013, 11:01 | #6 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: TELANGANA
Member: 1175976 Status: Offline Sonork: dgr Thanks Meter: 38 | Quote:
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
