Old 07-06-2007, 23:06   #1 (permalink)
j22
Member: 17931
Thanks Meter: 6
6280 screen reversed
How can I fix nokia 6280 when the screen is reversed. Screen is turned round in 180 degrees (upside down).
I have tried changing keyboard, flex, screen, and flash sw 6.10 but there is still same problem.
Old 07-06-2007, 23:09   #2 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
Have you checked LCD filters yet ???
Old 07-06-2007, 23:16   #3 (permalink)
j22
Member: 17931
Thanks Meter: 6
No, I dont check filters because picture on screen looks like good. But sw is freezing and phone is not usable.
Old 07-06-2007, 23:24   #4 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
LCD view is good but rotated or flipped can be caused by filters, but you haven't mentioned at first that the set get hanged !!!
Old 07-06-2007, 23:25   #5 (permalink)
j22
Member: 17931
Thanks Meter: 6
6280 screen reversed picture
Old 07-06-2007, 23:40   #6 (permalink)
j22
Member: 17931
Thanks Meter: 6
Could you tell me which exactly filter it is or both?
Thak you.
Old 07-06-2007, 23:45   #7 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
No sorry, i couldn't determine which filter may cause that, sometimes i replace them one by one & test after each, & sometimes i replace both at once .
But you have mentioned that the set get hangs, haven't you ? so it may be processor RAP3G defect .
Old 07-07-2007, 00:12   #8 (permalink)
j22
Member: 17931
Thanks Meter: 6
I have tested it again and result: screen is reversed, when push some item in menu screen is black or mixed and after about 2s is reversed. It is not freezing, sorry it is my mistake. I prefer your solution with filters. (Mp3 files playing without problems)
Question: did you change it every time or sometime rehot?
Old 07-07-2007, 00:20   #9 (permalink)
j22
Member: 17931
Thanks Meter: 6
Thak you,
your help is comprehensive.
I have to tried replace them one by one.
6280 screen reversed j22 Nokia Hardware & Hardware Repair 3 03-10-2015 12:28
6280 screen problems turnyny Nokia Hardware & Hardware Repair 8 05-29-2008 17:02
6280 screen backlight problem wydjet Nokia Hardware & Hardware Repair 16 05-03-2007 03:37
Nokia 6280 screen consam Nokia Hardware & Hardware Repair 2 01-01-2007 08:07
E 700 screen reversed draz1e Samsung Hardware Repair 3 07-15-2006 19:22
Page generated in 0.16996 seconds with 10 queries
