11-29-2003, 17:36 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: none Age: 49
Member: 11926 Status: Offline Thanks Meter: 0 | 6210 network when I put hand on the phone It gets network, but if I put my hand on the top of the phone (closing my hand where the antenna is) it starts losing network, like if I'm barrying the network I already changed PA, Antena Switch, reflowed cobba, hagar and ccont Any idea how to fix this ? Thks |
12-10-2003, 19:51 | #6 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | Here is a slow aproach: 1. Desolder PA... 2. Desolder Duplexer.. 3. Enable Net Monitor menu.. 4. Solder a wire from ANT (Duplexer) to GSM/PCS output (of Duplexer). 5. Start phone and go to the Net Monitor menu and enter test #01. 6. Look at RSSI reading. Tell us the results... Regards b0ba |
12-10-2003, 20:57 | #7 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | simply you have broken anntena pads on board when you press you lose the signal try this please 1-short the bothe anntena jack 2-resolder the anntena pads on board 3-change the anntena br. |
Info about relatio between first digits of the imei and the network on the phone | -luigi- | GSM Programming & Reverse Engineering | 3 | 05-17-2008 09:12 |
D500EXEEl1 when sim put on the phone auto off | chris2007 | HWK | 4 | 12-14-2007 10:27 |
E315 When i Put Batery 3 SeCond Phone Power On | Mierdita | Samsung Hardware Repair | 0 | 11-30-2004 22:23 |
(7110) When i put the flash cable in the phone i cant turn on the phone | sikH | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-08-2004 02:43 |
(3410) When i put the flash cable in the phone i cant turn on the phone | sikH | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-31-2003 17:25 |
