07-18-2009, 09:46 | #47 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
mostly this problem comes when we change the casing or housing of phone speaker doesn't fit on his location thats why the sound concentrate outside and not comes from his proper location... change original casing and housing then post result | |
07-18-2009, 09:53 | #48 (permalink) | |
07-18-2009, 09:59 | #49 (permalink) | |
07-19-2009, 20:48 | #51 (permalink) |
Junior Member Join Date: Sep 2005 Age: 43
Member: 184703 Status: Offline Thanks Meter: 5 | hi friend i was faced same problem in 6233 set i tried hardware .but no way then i tried small trick. first u need too place the original speaker in its housing it should have hole in the center of magnet (i try with that type reciver) than take a black sticker (u wel get in any local panel) cut that and stick it on the recivers boder and fix it that all and that sound come ture stright hole in the panel thats worked for me on 5 sets, i hope it will work for u friend |
07-20-2009, 03:27 | #53 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Quote:
use og bobby case because in og body spkr area cover with fom in this one control voice 's way i m also solve low voice problem for cover this area with fom sorry 4 poor english | |
07-20-2009, 09:25 | #57 (permalink) |
Crazy Poster Join Date: Jul 2009 Location: india
Member: 1075004 Status: Offline Thanks Meter: 13 | helloo brother i have solution of ur 6233 law speaker solution perfact 100% work but i am allrady new user so how can i send u diogram pls tell me guide me than i will send u pls |
08-12-2009, 22:55 | #59 (permalink) |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | 6233 low earpiece sound solution I read 58 post of this thread , its strange no one have right solution , it will solve your prob , if your ear filter are clean , then try it Rashid Ahmed Nadeem |
The Following 3 Users Say Thank You to r a nadeem For This Useful Post: |
6233 speaker voice is too low | micro_hsr | Nokia Hardware & Hardware Repair | 35 | 02-17-2010 19:32 |
8250 flash erasing error(battery voltage is too low) | gama_cell99 | Nokia Hardware & Hardware Repair | 8 | 06-01-2005 17:09 |
3310 flash erasing error (battery voltage is too low) | pana_java | Nokia Hardware & Hardware Repair | 2 | 04-04-2005 14:46 |
Flash erase check (battery voltage too low) | scanner | Nokia Hardware & Hardware Repair | 4 | 11-11-2002 17:29 |
Flash erase check (battery voltage too low) | scanner | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-08-2002 17:04 |
