Old 06-12-2009, 04:48   #1 (permalink)
Member: 145399
Thanks Meter: 26
6280 flashing
i m trying to flash 6280 but cannot flash. It gives error. here is log.
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm7830006.430.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm783006.43.ppm_a
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-78\rm7830006.43.image_a
APE Variant file: NONE
Languages in ppm: English,German,Finish,Swedish,Danish,Norwegian,Ice landic
Booting phone...
Error sync the phone...
Backing up CRT...
Detected P-KEY: 9000AA1A
P-key nokia module version 01.02
Init usb communication...
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Not found!!!
Backing up CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 02.31.000 RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting..............................Error booting phone...
Backing up CRT...
Reading IMEI...
Failed! Aborting!
PRESS POWER ON NOW!
Using 06.02.002
Stage 2 starting.......................................... .................Loader Sent!
Stage 3 starting..........Phone prepared OK!
Waiting for the phone to boot...
Phone failed to boot in flash mode CMT...
please guide. the set was on before flashing but now dead.
Old 06-12-2009, 05:08   #2 (permalink)
Registered User
Member: 828691
Thanks Meter: 33
sir try change a good cable
Old 06-12-2009, 05:19   #3 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
use fbus cable,, some time usb not flash phones... if set is dead
Old 06-12-2009, 05:22   #4 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 571
yes kapil cable problem
Old 06-12-2009, 05:25   #5 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Booting phone...
Backing up CRT...
PRESS POWER ON NOW!
Backing up CRT...
PRESS POWER ON NOW!
Using 06.02.002
Backing up CRT...
Reading IMEI...
Failed! Aborting!
PRESS POWER ON NOW!
Using 06.02.002
brother did u try fbus cable?
i think fbus cable connecting phone show CMT loder not found error
i think this is not cable problem
problem like hardware just wash and rehot pcb then try to flash
Old 06-17-2009, 07:11   #6 (permalink)
Member: 145399
Thanks Meter: 26
I tried to connect with fbus cables but didn't connect. also washed set but still same problem. set was alive before flashing.
Old 06-18-2009, 09:11   #7 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
post ur alog of fbus process..may be ur handset have hardware fualt...
I flash 6280 flash to 6131 arobi Nokia Base Band 5 ( BB-5 ) 2 10-05-2006 09:30
6280 flashing on USB is possible??? Blacki Phoenix Black Box 31 05-31-2006 13:20
6280 flashing on USB is possible??? Blacki Nokia Base Band 5 ( BB-5 ) 0 04-10-2006 08:54
help 6280 flash ibra13 MT-BOX 10 04-06-2006 15:15
Page generated in 0.14602 seconds with 9 queries
