07-03-2008, 22:56 | #1 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 429524 Status: Offline Thanks Meter: 3 | Nokia 6280 Headphone Icon I have searched a lot for the Nokia 6280 problem and its solution. Some point I still havent got cleared as I couldnt found them anywhere. If I switch the phone I hear Nokia startup voice as normal from speakers. But as soon as it gets to the main phone software it shows a headphone icon on the top. I cant hear anything even connecting a headphone (playing any media file) Now is it a hardware problem or software problem? If you say its pop port problem. Then why nokia start up voice comes from speakers phone. And do anybody have a step by step pop port removal video or instruction? OR is there any other shortcut to this problem by using jumpers. |
The Following User Says Thank You to aaho For This Useful Post: |
07-03-2008, 23:06 | #2 (permalink) |
Crazy Poster Join Date: Sep 2007
Member: 582265 Status: Offline Thanks Meter: 5 | just connect your 6280 headphone and switch off your phone with connected head phone and switch on your phone with connected head phone and out the head phone after this your problem will be solve 100% i say. |
07-04-2008, 07:39 | #3 (permalink) |
Member: 429524 Status: Offline Thanks Meter: 3 | no its not working ankitmodi. I have JAF. I have flashed it just to check if there is any software problem. After flashing its still the same. I have tried to boot it into normal mode using JAF. it booted normal and without headset icon. but again when I boot it with putting battery the headset icon comes again. I think may be there is some problem with battery connection. |
07-04-2008, 08:10 | #4 (permalink) | |
Junior Member Join Date: Feb 2007
Member: 451235 Status: Offline Thanks Meter: 0 | try this Quote:
07-04-2008, 10:03 | #6 (permalink) |
Junior Member Join Date: Feb 2008 Location: GREECE
Member: 707088 Status: Offline Sonork: moonstarmobile Thanks Meter: 0 | hey man hey man the startup tone is cming from buzer if u seen a headphone icon in ur telephone just give hot to popport connector ( headphone jack) after that its 100% ok i have more experienced in this problem & i rectified this prblm many more times |
07-04-2008, 11:24 | #7 (permalink) | |
Member: 429524 Status: Offline Thanks Meter: 3 | Quote:
I got an idea about buzzer.. how much heat must be given and at what specific area. Can you explain a little? thanks | |
07-05-2008, 05:01 | #10 (permalink) |
Freak Poster Join Date: Jun 2006 Location: dubai
Member: 302306 Status: Offline Thanks Meter: 44 | 6280 Hand Free Solution HI aaho BRO 1ST OF ALL CHANGE HAND FREE JAKE THEN CHANGE THESE ICS ONE BY ONE I HOPE YOUR PROBLEM WILL BE FINE BEST REGARDS GSM STROONG |
The Following User Says Thank You to gsmstroong For This Useful Post: |
07-05-2008, 23:27 | #13 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | Why this condition happen??. This condition happen, because swicth headset on automatic in few secon after phone startup. You have to look for polar capasitor that semi shorted. try step by step solution : 1. clean, replace or change ur plug in. 2. change or remove all polar capasitor there conected with all pin in ur plug in. 3. Change ur jeck 1-3 -- many phone in this condition 4. Ur power IC, -- clean, replace .. good luck sir |
nokia ngageQD headphone | rezabhai | Nokia Hardware & Hardware Repair | 0 | 09-23-2008 11:45 |
nokia 3220 headphone on screen | jacob magembe | Nokia Hardware & Hardware Repair | 5 | 04-09-2008 12:46 |
Nokia Bluetooth HeadPhone Device | NokiaMobileCare | Nokia Hardware & Hardware Repair | 3 | 12-27-2007 19:44 |
6680 showing headphone icon | citylight | Nokia Hardware & Hardware Repair | 4 | 10-20-2007 23:26 |
nokia 6101 headphone symbol | Johnessen | Nokia Hardware & Hardware Repair | 1 | 08-24-2006 06:25 |
