12-19-2009, 16:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: IN FRONT OF YOU Age: 44
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | 6300 3110 restart solution Br Asghar Hussain Dont forget to press thanks button |
The Following 9 Users Say Thank You to mobilecitycbk For This Useful Post: |
12-20-2009, 04:09 | #2 (permalink) |
Member: 475440 Status: Offline Sonork: 1604067 Thanks Meter: 965 | First try to rehot normaly the flash ic if not work than change tested works 100% Br Asghar Hussain |
The Following User Says Thank You to mobilecitycbk For This Useful Post: |
12-29-2009, 13:58 | #5 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | how are u my dear..are u ok..if some one chang flash ,,so,,where was gone imei ,,u know..must chang cpu and flash,,,,both of ,from an other set, |
12-29-2009, 14:33 | #6 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Sidoarjo City,Indonesia. Age: 27
Member: 706886 Status: Offline Thanks Meter: 59 | remember...just restart problem.so,we can make rpl back up first.after change flash chip then imei gone 12345654321?.full erase,reflash and write from rpl back up.bb5 phone imei ,store in cpu/rap. tested by me. |
07-29-2012, 19:49 | #8 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1791172 Status: Offline Thanks Meter: 0 | Hi, what is CTC? alcohol? and when you say reheat, do you mean put hot air on the surface for a minute? thanks. Y have a Nokia 6300b RM222 and it keeps powering on and off when a SIM card is inserted. |
07-29-2012, 20:05 | #9 (permalink) | |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | Quote:
use alcohol or spirit oil,**** hot air around ic for repair bad ic connection. BR Nizda Mobile | |
07-29-2012, 20:19 | #10 (permalink) |
Member: 1791172 Status: Offline Thanks Meter: 0 | thank you Nizda. i used isoprohpilic alcohol and tyhen hot air, but it seems as my 6300 is now dead, cos when I turn it on it only flashes the side blue leds and nothing happens in the LCD. back then at least it started. Ill try doing the same again. cheers. |
6300,3110c restart solution here........ | chohansahib | Nokia Hardware & Hardware Repair | 9 | 02-18-2011 07:40 |
Nokia 6300 restart solution needed.. | tutu1982 | Nokia Hardware & Hardware Repair | 6 | 11-15-2009 01:50 |
3110,6300,3500 mmc solution 100% tested | rishi1985 | Nokia Hardware & Hardware Repair | 1 | 10-24-2009 17:43 |
nokia 6300/3110 solution by hardwear | varun_73 | Nokia Hardware & Hardware Repair | 3 | 04-12-2009 07:12 |
Nokia 6300 restart solution needed.. | tutu1982 | Nokia Hardware & Hardware Repair | 8 | 08-09-2008 14:20 |
