12-02-2008, 20:32 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 730410 Status: Offline Thanks Meter: 0 | 6300 dead pressing the on/off only the side light (left and right light) is turning on and it stays on till i am holding the on /off button,please say what i should do by sending the solution with picture |
12-16-2008, 19:27 | #2 (permalink) |
Junior Member Join Date: Oct 2008
Member: 882232 Status: Offline Thanks Meter: 1 | hi i have also a dead 6300, but without any lights on both left and right side. i have full 6300 manual but stuck. 0. it is a water damaged phone. 1. i have checked the current consumption, it only draws at most 0.04 A when the power button pressed. and 0 when the power button released. 2. it has shorting. 3. i have followed the "General Power checking troubleshooting" 4. i checked the c2307 voltage. it is the same as VBAT. now the question is : 1. (please look at the image, excerpt from 6300 general power checking troubleshoooting) ARE PURX (J2216) and RSTX (J2218) signals OK ? PURX=1.8V, RSTX=VBAT) Measure before watchdog phone turns phone off. i put my tester on that testpoint, both are 0 Volt. now where should i check next, check RETU VIO or Tahvo VCore ? 2. i just check the two of them to but still AT c2302 = 0 v, and c2215 =0 v. 3. that logic says "WATCHDOG phone". what is meant by watchdog ? 4. how to check them Thanks [URL=http://img519.imageshack.us/my.php?image=6300xj0.jpg] |
12-16-2008, 19:38 | #3 (permalink) | |
Freak Poster Join Date: Nov 2007 Location: inside Phone
Member: 631496 Status: Offline Sonork: 100.1581341 Thanks Meter: 112 | Quote:
try flash phone with latest fw post result br | |
12-16-2008, 22:36 | #4 (permalink) |
No Life Poster Join Date: Jul 2008 Location: H.DALAA Age: 48
Member: 820444 Status: Offline Sonork: 100.1680641 Thanks Meter: 466 | hi bro's i have 6300 dead when i change pattry . i try to flash but phone not responding . i clean and rehaet the phone but same problem . any solution please , whith picture please . --------------- bro. --------- lahdache |
6300 dead after flash 6233 dead after flash | mobileZONE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 01:17 |
