02-06-2004, 09:16 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | 6310 (NPL-1) dead i have a 6310 dead i have flashed the phone, but no way , then tried to rehot the phone but same result remains... when i try to measure the voltage of the set at the display pins and the keyboard pins, i can get some voltages in some pins just for a second and it again goes off, i get nearly 2 volts at the keyboard, and at the display pins i get 1 to 4 volts..., please help me repair that... thanks |
02-06-2004, 12:18 | #2 (permalink) |
Freak Poster Join Date: Jul 2002 Location: MAD Age: 50
Member: 13545 Status: Offline Thanks Meter: 2 | Does the phone accept flashing ...? if it accept flashing then reball/change Check VBAT value ....., is it 3.6V ....? ( after u plug in the charger ) if it is 3.6V then mostly UEM is good ..., check sleep clock J404,FLASH IC if not then UEM faulty in most cases ... good luck ------------- MrHazeem |
NPL-1 dead after sw update | Invisible | Trisha & Matrix Flasher | 8 | 11-16-2003 00:24 |
Can not load,the product NPL-1 is not registerd | Byte | Nokia Hardware & Hardware Repair | 0 | 09-27-2003 09:57 |
npl-1 | surany | Nokia Multimedia | 9 | 08-19-2003 21:25 |
6310i NPL-1 351453207654373 216-30 please.. | crusher | Phone Unlocking Codes & Maps | 1 | 03-15-2003 20:48 |
6310i NPL-1 IMEI 351110204449096 SP 216-01 calculate please! | crusher | Phone Unlocking Codes & Maps | 3 | 03-03-2003 23:46 |
