Old 08-26-2005, 18:44   #1 (permalink)
Member: 43545
Thanks Meter: 7
6310 spk problem
hi
1. i have nok.6310 spk is not working but mic is workin.
2 .when i use h/f is spk & mic both are working is there have any hint or way of spk.....(track)thanks
Old 08-27-2005, 10:37   #2 (permalink)
Member: 119769
hello.
in 6310 and 6310i spk goes from spk pads to UEM
only one element is beetween spk and uem! this is small double resistor.
czeck connections beetween spk pads and this small resistor.
this resistor is on the left side of uem when you have a PA upside and a hf connector down.
this is a R171
if You have this connection try to reflash your phone with good PM and PP and if it's still not working I think You have a bad UEM or broken connetion beetween UEM and R171 :-( UEM is glued so i think it's not possible to repair it...
v3x spk problem heeeeeeeeeelp! gharibiarian Motorola Hardware Repair 1 05-29-2008 15:54
6233 spk problems mobilecarerke Nokia Hardware & Hardware Repair 6 02-04-2008 13:35
3100b to 3100 spk problem DYNET Nokia Hardware & Hardware Repair 15 10-01-2007 18:35
Nokia 6030 Spk Problem .:Towhid:. Nokia Hardware & Hardware Repair 2 06-24-2007 20:10
sgh-v200 spk problem habibkhalil Samsung Hardware Repair 0 05-07-2006 12:13
Page generated in 0.12629 seconds with 9 queries
