09-28-2008, 17:09 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 289307 Status: Offline Thanks Meter: 44 | 6600 nhl-10 flash problem Fl0: 0x00000000-0x007FFFFF,0001267E,Amd 29BDS643HT Fl1: 0x02000000-0x027FFFFF,0001267E,Amd 29BDS643HT Fl2: 0x04000000-0x047FFFFF,0001267E,Amd 29BDS643HT Fl3: 0x06000000-0x067FFFFF,0001267E,Amd 29BDS643HT Algorithm: w2_amd.fia, w2_cbusb.fia, Ver: 4.55.0 Algorithm Ok, MSID: 8442DF5ECF751FD7E0DA35D113 Decoded MSID: 3E4EBAF7-00C34A3A-A9000000 Encoded FAID: 4BE64E84-B14E3C46-1B1ADE93 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x007FFFFF Erased, Time: 01:18 Area3: 0x04000000-0x046FFFFF Erased, Time: 01:07 Area4: 0x06000000-0x066FFFFF Erased, Time: 01:05 Area5: 0x047C0000-0x047EFFFF Erased, Time: 00:01 BT MCM (21) Image Found: 0x0002DD94 Write Error: hDat 14, at: 0x00020000:08 Process Failed, Repowering Mobile |
09-28-2008, 17:58 | #4 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | if you uncheck bt flashing mobile take flashing but you can't able to use bluetooth so replace bluetooth module with new one you can eaisaly avail in the market |
09-28-2008, 18:09 | #5 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | Quote:
If same problem, i think that is hardware problem Try step by step my solution sir 1. Change m_jolner 2. Change zocus and smps ic 3. Reheat or reball or change UPP Many condition will caused M-jolner | |
6600 nhl-10 after flash dead | fofolpo | UFS2 + UFS3-Tornadoflasher | 2 | 08-15-2009 12:02 |
6600 nhl-10 flash prolem | zacksonite | n-Box | 0 | 09-28-2008 17:10 |
Flash 6600 NHL-10 with chinese flash?? | epic | Nokia Digital Core Technology 4 ( DCT-4 ) | 24 | 02-23-2004 03:48 |
info Nokia 6600 nhl-10 | miroservice | WD2 & APE (Symbian Phones) | 1 | 12-15-2003 12:34 |
