Old 11-06-2008, 14:12   #1 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
7610 startup field
nokia 7610 startup field;after
i full flash in higher version; unlock full format erase flash
and selfformat problem is still
pls help....................................
The Following User Says Thank You to jaleelkuttikkar For This Useful Post:
Old 11-06-2008, 18:41   #2 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
plssssssssssssssssssssssssssssssssssssssssssssssss ssss
Old 11-06-2008, 19:15   #3 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
change flash user....................
Old 11-06-2008, 19:25   #4 (permalink)
Member: 591669
Sonork: 110011
Thanks Meter: 687
sir; pls explain........................
Old 11-06-2008, 20:07   #5 (permalink)
Member: 858670
hi..
i used to rehot or change driver LCD IC and zocus.
nokia 7610 startup failed contact the retailer nishatmohd Nokia Hardware & Hardware Repair 11 10-04-2011 16:48
7610 startup problem m.tahir Nokia Hardware & Hardware Repair 8 11-26-2008 21:42
7610 startup failed vicky kumar Nokia Hardware & Hardware Repair 19 05-17-2008 08:21
7610 startup failed vipul manchanda Nokia Hardware & Hardware Repair 8 08-19-2006 04:48
7610 Startup Code? Devil_H@ck WD2 & APE (Symbian Phones) 7 03-01-2005 22:47
Page generated in 0.14274 seconds with 9 queries
