05-16-2008, 12:38 | #2 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! 1st try to fullfactory then format your phone with flashing device. If same then try to manually format (* Key+3 Key+calling Key+power button) Last edited by irfanamin2; 05-16-2008 at 12:44. |
05-16-2008, 13:02 | #9 (permalink) |
No Life Poster Join Date: Aug 2006 Location: melbourne australia thailand Age: 48
Member: 338192 Status: Offline Sonork: 1678261 Thanks Meter: 154 | problem is reflow flash ic and cpu ic and hold .....3*call botun hold prest to power botun and hold 7 second do formeting than fon its 100%%%%%% GOOD |
05-16-2008, 17:37 | #14 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Try to completely erased the flashed n write update firmware the write good pm your problem is solved. Thankz. Xtreme Mobile. BRB. |
nokia 7610 startup failed contact the retailer | nishatmohd | Nokia Hardware & Hardware Repair | 11 | 10-04-2011 16:48 |
7610 Phone Startup failed Contact to Retailer | Kethey | WD2 & APE (Symbian Phones) | 28 | 08-05-2009 08:32 |
7610 startup failed | vipul manchanda | Nokia Hardware & Hardware Repair | 8 | 08-19-2006 04:48 |
7610 contacts menu problem with startup failed | PERSIA-GSM | Nokia Hardware & Hardware Repair | 12 | 03-02-2006 21:57 |
