11-08-2008, 09:22 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: In my body
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | 6600 problem After flash the phone is dead ... I use following flash files NHL105530.C1 NHL105530.C7 NHL105530.34 NHL105530.65 Any thing wrong in this selection? |
11-08-2008, 09:33 | #3 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: UK Age: 45
Member: 318277 Status: Offline Thanks Meter: 92 | Quote:
First chk what was the firmware version before u flash .. anyway now make sure ur PCb is clean and if so Full erase first and flash with main flash and PPM of the latest version and make UI settings ,Then FORMAT USER AREA..must b ok bro Post results BR | |
11-08-2008, 09:43 | #4 (permalink) | ||
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Quote:
When i flash it again which file should i select as mcu (C1 or C7) ..... This phone is made in china. | ||
11-08-2008, 11:09 | #5 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | erase phone with erase file you can find it in this forum after that full flash the phone I think your problem will be solved , post result |
11-09-2008, 09:44 | #6 (permalink) |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Getting MCU ID MCU ID: 0x0082 FLASH ID0: 267E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 267E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 267E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 267E0001 <=> SPANSION -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.01 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: E:\PHONE\FLASH\NOKIA\##MCU+PPM+CNT##\NHL-10 6600\Repair JAF\6600_fulleraseJAF.fia CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! ............... Failed to backup imei... PPM: E:\PHONE\FLASH\NOKIA\##MCU+PPM+CNT##\NHL-10 6600\Repair JAF\6600_fulleraseJAF.fia Booting phone... MCU ID: 0x0082 BOOT file: C:\Program Files\ODEON\JAF\Flash\w2_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x1058 Boot is ready... FLASH ID0: 267E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 267E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 267E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 267E0001 <=> SPANSION -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x267E0001 Flash loader is C:\Program Files\ODEON\JAF\Flash\w2_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7168; Loader chk: b6 Loader is ready... P-key nokia module version 01.01 MSID: 84D647AA15C5CCB6B3087F9AE3 MSID decoded: 3E4EBAF7005C5719A8000000 FAID: EDAB2954FF8E68F6D69ED000 Operation took 0 minutes 21 seconds... Erasing PPM... Found 5 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 007FFFFF... Erasing area: 02000000 - 027FFFFF... Erasing area: 04000000 - 047FFFFF... Erasing area: 06000000 - 067FFFFF... Operation took 4 minutes 52 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Flashing Done! Operation took 5 minutes 41 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! ........... Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 PPM Flash file: E:\PHONE\FLASH\NOKIA\##MCU+PPM+CNT##\NHL-10 6600\Repair JAF\6600_fulleraseJAF.fia CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.65 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: O2,UK Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! ................ Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 Booting phone... MCU ID: 0x0082 BOOT file: C:\Program Files\ODEON\JAF\Flash\w2_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x1058 Boot is ready... FLASH ID0: 267E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 267E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 267E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 267E0001 <=> SPANSION -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x267E0001 Flash loader is C:\Program Files\ODEON\JAF\Flash\w2_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7168; Loader chk: b6 Loader is ready... P-key nokia module version 01.01 MSID: 84B48660EBE7A618DC30274922 MSID decoded: 3E4EBAF7005C5719A9000000 FAID: 2A33778126C082BD801B8AA2 Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_cbusb.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x2020; Loader chk: 7f Additional Loader is ready... Operation took 0 minutes 23 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 007FFFFF... Erasing area: 04000000 - 046FFFFF... Erasing area: 06000000 - 066FFFFF... Erasing area: 047C0000 - 047EFFFF... Operation took 3 minutes 26 seconds... Writing... MCM Register OK Perm. Data Restore OK Operation took 5 minutes 30 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.65 Booting phone... MCU ID: 0x0082 BOOT file: C:\Program Files\ODEON\JAF\Flash\w2_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x1058 Boot is ready... FLASH ID0: 267E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 267E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 267E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 267E0001 <=> SPANSION -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x267E0001 Flash loader is C:\Program Files\ODEON\JAF\Flash\w2_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7168; Loader chk: b6 Loader is ready... P-key nokia module version 01.01 MSID: 84D647AA15C5CCB6B3087F9AE3 MSID decoded: 3E4EBAF7005C5719A8000000 FAID: EDAB2954FF8E68F6D69ED000 Operation took 0 minutes 20 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02000000 - 020DFFFF... Operation took 0 minutes 8 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 12 seconds... Restarting MCU... Flashing Done! Operation took 10 minutes 32 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: NHL-10, Software version: 5.53.0 IMEI: 351546001994497 Product Code: Resetting PPC... Done! |
11-09-2008, 09:49 | #7 (permalink) |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Use erase file & flash the latest version, but no luck Phone still dead ............. Tell me somthing to do, customer is waiting ....... regards |
11-09-2008, 10:14 | #8 (permalink) |
Member: 544160 Status: Offline Sonork: 100.1603100 Thanks Meter: 178 | Can't do factory set ............... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... Master Code: 2126007166 Failed! Aborting! MCUVER FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 5.53.0 30-12-04 NHL-10 (c) NMP HW version: PCI version: UEM version: 8 UPP version: 130 Production serial number: Product code: Module code: Basic production code: Flash code: Order number: Long production SN: ATO: Default SN type: IMEI plain: 351546001994497 IMEI spare to net: 3A 15 45 06 10 99 44 09 IMEI SV to net: 33 15 45 06 10 99 44 09 F9 PDC: 4E 54 54 4A 50 12 34 56 Master Code: 2126007166 Phone type: NHL-10, Software version: 5.53.0, Language Pack: 65 User code: 12345 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_NHL-10.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: INI file .ini is missing. Continue searching for second ini type... No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\351546001994497_imei_back up_1427911.rpl Done! Backup imei OK! Flashing Done! Operation took 0 minutes 2 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: NHL-10, Software version: 5.53.0 IMEI: 351546001994497 Product Code: Resetting PPC... Setting FULL FACTORY......Setting test mode... Failed! Aborting! Failed! Aborting! Done! |
6600 problem with Oxygen phone manager! | pedjulino | Nokia Multimedia | 6 | 05-06-2004 20:57 |
Nokia 6600 problem | Unlocker AL | Griffin | 2 | 05-06-2004 18:19 |
6600 problem | gsm-decode | Twisterflasher | 2 | 05-04-2004 09:19 |
PC suite for Nokia 6600 problem,Heeeelpe me | tareg2001 | WD2 & APE (Symbian Phones) | 0 | 03-21-2004 17:49 |
6600 problem... reminds me of 3650 fading :( | Burnt Cobba | WD2 & APE (Symbian Phones) | 2 | 12-16-2003 16:07 |
