04-20-2007, 13:28 | #5 (permalink) | |
Major Poster Join Date: Dec 2006 Location: jaipur Age: 37
Member: 412881 Status: Offline Thanks Meter: 4 | Quote:
first step-flash the phone mcu,ppm in erase file and then set all areas erasing and flash aeas blank and try to ui option full factory,ui default and init simlock after do it format user area and write pm your set is working ok and this probs not solved then change the display ic ok | |
04-20-2007, 15:52 | #7 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Lahore, Pakistan
Member: 234653 Status: Offline Thanks Meter: 83 | 6600 white lcd solution Quote:
Hafiz Mobiles | |
The Following User Says Thank You to hafizjee For This Useful Post: |
06-06-2007, 03:06 | #11 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 520956 Status: Offline Thanks Meter: 12 | bro,try to full erase then rewrite and put N36bigPM..or try to change LCD from other phone if not working,,reheat the flash ram the white colored one near flash ic..it will ok |
6600 White Lcd | W4r10rD | Nokia Hardware & Hardware Repair | 23 | 01-25-2008 09:19 |
7610,6600 White Lcd | FasGsm | Nokia Hardware & Hardware Repair | 1 | 08-17-2006 09:23 |
6600 white lcd | The Repair Shop | Nokia Hardware & Hardware Repair | 23 | 02-15-2006 20:11 |
6600 white lcd... | Byte | Nokia Hardware & Hardware Repair | 11 | 05-18-2005 15:38 |
6600 White Lcd | FITOS | WD2 & APE (Symbian Phones) | 5 | 02-28-2005 08:11 |
