12-26-2006, 03:38 | #1 (permalink) |
Freak Poster Join Date: Dec 2004
Member: 96236 Status: Offline Thanks Meter: 7 | 6600 white screen only can you help me before i use the hammer on this crap br |
12-26-2006, 06:18 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 41
Member: 356202 Status: Offline Thanks Meter: 46 | i think this unit spoils your christmas holiday...... hehehe.. try to replace the ic in the upperpart of rhe bat connector..... some of this problem coming from the cpu.. might try to reflow or otherwise replace.. wbr |
12-26-2006, 08:35 | #4 (permalink) |
Member: 96236 Status: Offline Thanks Meter: 7 | @gsm_blue cpu! cpu! cpu! its the cpu! G o d bless you one reason this 6600 really spoils my holiday is because i already fixed it even tested it for quite some time (memory card corrupted) but when customer came it screws up @all thanks thanks thanks all for info all sorted out, merry xmas! |
12-26-2006, 11:21 | #5 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Philippines - Saudi Arabia
Member: 396326 Status: Offline Thanks Meter: 229 | Quote:
take a look this attachement, reflow this IC or replace maybe it will help you.. capri | |
02-26-2007, 05:00 | #8 (permalink) | |
Member: 356202 Status: Offline Thanks Meter: 46 | Quote:
yes buddy there are two ic... just remove the small one and put jumper wire on it....... the other one just replace it.... or you can also put a jumper on it....... wbr | |
02-26-2007, 22:55 | #11 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | 6600 white screen only Quote:
little IC R385 (IP4043CX5)is just only protector and for safety if u only remove its the set will work well there is no need to jamper ,and no role in LCD display i think as.Athough N380 (LM3819BLX)has a main role . am i right sir ? if not plz guide me , regards rashid | |
02-27-2007, 04:48 | #12 (permalink) | |
i also thought it before that its just a protector..... but after a while the display will faid.... thanks R A NADEEM for this good conversation.. | |
N70 white screen only...flash with mt-box only boot failed...hardware or software | acelai00 | Nokia Hardware & Hardware Repair | 8 | 04-05-2007 11:02 |
Help need 6600 white screen,contact retailer i read all the post on forum...HELP | ZetMen | Nokia Hardware & Hardware Repair | 16 | 08-30-2005 09:32 |
my 6600 white screen.. helllp | Tbaba | WD2 & APE (Symbian Phones) | 11 | 04-01-2005 18:38 |
6600 white screen | -KimoAlex- | WD2 & APE (Symbian Phones) | 3 | 03-19-2005 23:57 |
6600 white screen! | sergioems | Sell ur Old and Used Stuff | 0 | 12-05-2004 14:31 |
