Old 06-03-2004, 14:38   #1 (permalink)
Member: 7586
Thanks Meter: 11
6610 freezing
Hello
6610 freezing after few seconds after power up.
on selftest gives this error :
No signal - ST_IR_LOOP_TEST
does any1 knows what should be the problem please?
i will also welcome if any1 has descriptions of all tests in SELFTEST.
b.r.
Pali
Old 06-12-2004, 19:15   #2 (permalink)
cellcity's Avatar
Member: 58052
Thanks Meter: 21
Talking
Originally Posted by pali
Hello
b.r.
Pali
WELL REFLOW PCB AND TRY TO RELOWD SOFT AGAIN
Old 06-21-2004, 15:39   #3 (permalink)
Member: 7586
Thanks Meter: 11
not helped.
i have relowed it and flash new sw version but problem still remains.
pali
Old 06-23-2004, 06:40   #4 (permalink)
Member: 69056
Exclamation
hav you tried to restore factory dfaults after flashing?
try to format the user area also maybe your 6610 has ran out of memery or memory low...
tryto change flash ic...
Old 06-23-2004, 08:49   #5 (permalink)
Member: 7586
Thanks Meter: 11
ram ic changed, flash ic changed , uem changed, flash new version, fact. default.
When i power on the phone with sim card and leave it in ENTER PIN msg , phone is powered on more then 2minutes(i test just 2 minutes, maybe it will be longer) but when i enter pin, after few seconds it will freeze then power off. But when i make call after entering pin and logging to network i can call .
I tried 2minutes call , then when i end call phone will freeze and then power off.
Pali
Samsung C5510 phone freeze quayson81 Z3X-Team Products 1 03-30-2010 12:58
P910 phone freeze how un-freeze whith ns-pro? .:Ripgsm:. QUALCOMM Models (3G) 0 01-11-2010 10:41
ZV40 phone FREEZE, i can make unlock but phone still freeze, how to fix it ? PSG UST Pro II 1 10-19-2006 20:31
saya mencari pm 6610./i find pm 6610 masirfan Griffin 1 08-29-2004 17:29
6610 Rom3 All locks CLOSED. HELP!!! Max468 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-12-2002 22:05
Page generated in 0.24222 seconds with 9 queries
