02-12-2007, 14:54 | #1 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 139043 Status: Offline Thanks Meter: 27 | 6610 turns off when I press any button on phone What shall I do???? |
02-12-2007, 15:45 | #4 (permalink) |
Freak Poster Join Date: Nov 2003 Location: Olympia
Member: 44950 Status: Offline Thanks Meter: 10 | yes, check the switch on the side volume. normally the lower switch is always the culprit. but if the problem still exist you need to upgrade and check the upp and flash ic.... |
02-13-2007, 14:07 | #7 (permalink) |
Member: 139043 Status: Offline Thanks Meter: 27 | Thanks for the advice I have replaced all the switches including the volume switch but its still the same. I will try to rehot cpu and I will post reply tomorrow. Please let me know if there is any other solution. |
3310 problem when i press any button set is off | shani72 | Nokia Hardware & Hardware Repair | 1 | 10-15-2008 13:39 |
L6i TURN OFF WHEN PRESS ANY KEY | jamohaki | Motorola P2k | 1 | 05-13-2008 10:26 |
L6i SWITCH OFF WHEN PRESS ANY BUTTON | jamohaki | Motorola Hardware Repair | 0 | 04-12-2008 08:02 |
8800 turns off when i press any button | ashok2 | Nokia Hardware & Hardware Repair | 2 | 09-04-2006 10:52 |
