Old 07-13-2004, 10:05   #1 (permalink)
RAHUL12345's Avatar
Member: 59915
Thanks Meter: 4
6610i not charging
hey guyz i have 6610i which displays not charging immediately after inserting charging pin.i have occured same problem with 3100.But no solution for that..
PLz help me
Battery, charger,charging connector is OK
Resoldered K fuse but no soln..
Thanx in advance
The Following 2 Users Say Thank You to RAHUL12345 For This Useful Post:
Old 07-13-2004, 12:10   #2 (permalink)
Member: 45635
Thanks Meter: 20
it is so easy .... just change the UEM ic ( tested 100% )
The Following User Says Thank You to MAJESTIC PIRATE For This Useful Post:
Old 07-14-2004, 02:05   #3 (permalink)
Member: 16036
Thanks Meter: 5
HI MAN
yes
pirate 1000% correct
but before you DECIDE to change uem
i SUGGEST you to REBALL or rework with flux
this might just save u some xtra $$$
keeep well
bye :
The Following User Says Thank You to mohammed For This Useful Post:
Old 07-14-2004, 19:16   #4 (permalink)
RAHUL12345's Avatar
Member: 59915
Thanks Meter: 4
sorry but, where can i find this UEM IC...
Old 07-14-2004, 23:59   #5 (permalink)
Member: 45635
Thanks Meter: 20
hi , max232 chip
its always fail just in not charging problem & not advisable !!!!.....
Old 07-15-2004, 10:04   #6 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
max232????? what's that chip has to do with charging
Old 07-17-2004, 13:49   #7 (permalink)
Member: 45635
Thanks Meter: 20
hi azampk :
its ma be success by your good luck !!!!
Old 07-19-2004, 01:52   #8 (permalink)
Member: 24929
Thanks Meter: 7
no no no what are you doing? the only thing you change are F100 and that's all, see picture
Old 01-27-2005, 13:12   #9 (permalink)
.:AnOuaR:.'s Avatar
Member: 62602
Thanks Meter: 6
6610i not charging
6610i not charging is not flash??????????
Old 01-28-2005, 02:03   #10 (permalink)
Member: 76745
question after that?
mmm change uem?? is rpl is just same like other?? ( 8310)
Old 09-05-2008, 16:46   #11 (permalink)
Member: 633809
Thanks Meter: 9
thanks goog work
go ahead
Old 09-05-2008, 17:01   #12 (permalink)
Member: 688669
Sonork: 100.1616789
Thanks Meter: 39
Arrow
change uem your problem maybe ok try it agian and agian ok best of luck.......................................ok
Old 09-05-2008, 19:07   #13 (permalink)
Member: 675717
Thanks Meter: 125
Smile
PLz help me
Thanx in advance
About 3100 you can find BSI capacitor behind battery connector remove this one.If not ok change UEM.6610i must be change UEM.
Old 09-05-2008, 19:18   #14 (permalink)
AdickAsia's Avatar
Member: 801083
Thanks Meter: 99
hey that post 2004.....
Old 07-15-2010, 07:06   #15 (permalink)
Member: 1092842
Thanks Meter: 12
Charging solutions
GSM NILBAGAN
Charging not supported..... and.....Not charging 100% solution R@ZIB-BD Nokia Hardware & Hardware Repair 20 04-06-2010 08:57
NOKIA Charging Not Supported & Not Charging NEW HARDWARE EXE dulal044 Nokia Hardware & Hardware Repair 2 05-16-2009 15:33
6610i not charging please rectify.......???? boopathyp Nokia Hardware & Hardware Repair 1 12-16-2007 10:54
Hello anybody, my Nokia-3210 is not charging it is showing not charging varma raj Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-25-2003 11:27
Page generated in 0.26287 seconds with 10 queries
