08-13-2006, 08:48 | #5 (permalink) | |
Junior Member Join Date: Jan 2005 Age: 44
Member: 103485 Status: Offline Thanks Meter: 2 | yyes Quote:
and when putting charger or call 112 no response Last edited by mone1; 08-13-2006 at 09:02. | |
08-26-2006, 04:11 | #7 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: India Age: 73
Member: 23587 Status: Offline Thanks Meter: 63 | Quote:
when putting charger or call 112 no response means that most likey is that your phone is not able to process any signals or not completely ON only. May be the phone had suffered physical damage and there are more parts than the broken lcd that have got damaged. One likely problem could be a displaced or a broken antenna unit causing no network. Please look for physical damage to such more other parts like Antenna, Antenna Switch, all connectors etc. Hope it helps. | |
08-26-2006, 06:49 | #8 (permalink) |
Junior Member Join Date: Feb 2006
Member: 229581 Status: Offline Thanks Meter: 2 | hi hi i think ur display controller ic is damaged . kindly rehot or replace if possible . mail me [email protected] |
08-26-2006, 07:03 | #9 (permalink) |
Junior Member Join Date: Jun 2006 Location: becool earth
Member: 299516 Status: Offline Thanks Meter: 0 | maybe your phone are damage they called as white screen just only lights on screen then nothing .......... if it is try to reheat samsung ic post the result search the thread much better!!! |
08-26-2006, 08:35 | #10 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 227361 Status: Offline Thanks Meter: 28 | BROTHER CHECK first incoming call and outgoing call if it is ok then replace lcd check first lcd conector .if it will remane same condition only heat it to ram .ok.but first flash it ................................ |
6300 only side blue light only !!!!!! | msantar | Nokia Hardware & Hardware Repair | 28 | 07-10-2012 05:19 |
now my box is showing only VBAT light only | ABDULLAHI MUHD | Cyclonebox | 1 | 11-13-2009 13:41 |
n81 8gb light only light | shami61 | Nokia Hardware & Hardware Repair | 1 | 05-28-2008 22:59 |
6630 Lights up when battery inserted. | pete.bartlett | Nokia Hardware & Hardware Repair | 2 | 08-28-2006 19:01 |
