07-26-2006, 20:15 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Egypt Age: 52
Member: 129676 Status: Offline Thanks Meter: 39 | 6630 restart - in software a full flsh with a new version and format and a new PM and the same problem - in hardwre replace the two power ic and the network ic's and the Helen upp and the same problem i gess that the restart problem come from the RAP3 upp like the WD2 phones but i can't replace it becouse of the unlocking . any buddy have a solution for this problem ?????? thank's for all |
07-27-2006, 01:42 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004 Age: 46
Member: 73797 Status: Offline Thanks Meter: 19 | Quote:
(and format it)utmost important. try code *#7370#, it will format the phone. no application or anyother material install neither through bluetooth or mmc(keep ur bluetooth off). I m pretty sure, its virus disturbing u. | |
07-27-2006, 10:32 | #6 (permalink) | |
Member: 129676 Status: Offline Thanks Meter: 39 | Quote:
07-27-2006, 13:46 | #9 (permalink) | |
10-16-2006, 15:02 | #10 (permalink) |
Insane Poster Join Date: Feb 2003 Location: Belgrade,Serbia Age: 55
Member: 23157 Status: Offline Thanks Meter: 0 | Hello Mr.Sameh Safa! Your question,and your work is for respect,but some answers in this thread are funny!Somebody dont read good... -------------------------------------------------------------------------- Are that phones from TIM?If they are from TIM you will see that is some different hardware than in olders 6630.I think that is hardware problem which can be solved on many ways, etc. good SDRAM could make that phone work better because it would give to the phone "much space",but problem still be somewhere...Like that phone will be restarting after few days,not after 5.minutes...Reall problem could be some of many things like stability of some power blocks(current and voltage),or it could be stability of clocks (32.768kHz,38.4MHz / fq and amplitude)...Power consumption of some blocks could be badly coused by some passive components like bad capacitors at some lines,etc... The best way (i think) is to power on some older (good),and at the same time one of your bad phones ,and go to measure clocks,voltage...And you can measure when they are in power off mode,you can to measure resistance at the same lines... When we power on the phone than phone software every second "watching" all information,condition...like temparature VCO...voltage,current consumption,etc...,and if some value are not good phone will be power off. Best regards! |
10-16-2006, 22:15 | #11 (permalink) | |
theank you again man yours sameh | |
10-18-2006, 20:30 | #12 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | sameh safa : rap ic's not defective, already tried change rap and nor from other phone, problem still exist, the rap and nor moved to other phone also works well without restart ... got a lot of it here, already change omap, combo flash, sram, thavo, retu, hinku, vinku, power amplifier .. no hint at all seems the restarting part only the helen part, cmt part doesn't restart , try using sim card with pin request, each time restart, never ask for pin confirmation, but don't know if it's the same problem there like here regards |
6630 restart ever 2 min ..... | ckkckk | Nokia Base Band 5 ( BB-5 ) | 13 | 12-16-2005 07:10 |
6630 restarting,here is log from mt-box | zoki | MT-BOX | 1 | 12-07-2005 17:57 |
6630 restarts atleast once a day | trafix | Nokia Base Band 5 ( BB-5 ) | 0 | 07-23-2005 10:57 |
