Old 07-24-2008, 06:28   #1 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
6300 Very Strange Blue Light Only Already Flash And Check Hardware
Hi Guys Need Ur Help I Have 6300 Only Blue Light I Already Serch In Forum There Many Post But My One Is Deffrent I Can Flash The Phone Can Flash Proper While Cable In Phone I Can Use Phone I Can Turn On Phone But When I Insert Bettery Phone Not Turning On Only Blue Light? Strange Aye?
I Already Try This Hardware Solution I Check That Test Point And Clean I Also Aply This Jumper But Stil Same So Can Anyone Please Tell Me What To Do?
Thanks
Salim
File Type: jpg SOLUTION HARDWARE 6300 again come with only side lights IF VCORE FROM TAHVO DROP UP.JPG (153.6 KB, 1295 views)
The Following 6 Users Say Thank You to MUTUAL For This Useful Post:
Old 07-24-2008, 06:32   #2 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
reball retu ic .......and post result.....
digitized
The Following User Says Thank You to digitized For This Useful Post:
Old 07-24-2008, 07:14   #3 (permalink)
Member: 818748
Sonork: 00000
Thanks Meter: 44
i have also a problem same problem,,,,give me some idea
Old 07-24-2008, 07:51   #4 (permalink)
Member: 461923
Thanks Meter: 2,020
..same problem..after i change THAVO phone work good ...
Old 12-15-2008, 06:20   #5 (permalink)
arifksarmali's Avatar
Member: 259084
Thanks Meter: 232
change thavo ic is solution for this problem i use this solution for 6300
Old 12-15-2008, 06:27   #6 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
brother chang thavo ic
i hope your pro.......... slod..............
Old 01-07-2009, 07:38   #7 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
I WAS TRY THIS SOLUTION ITS ONLY 50% work
sp
Old 01-07-2009, 07:59   #8 (permalink)
Member: 688669
Sonork: 100.1616789
Thanks Meter: 39
Hello all bro
HI ALL SWEET HEART I HAVE ALSO THIS PROBLEM PLZ ANY IDEA
Old 01-07-2009, 08:04   #9 (permalink)
Member: 894862
Thanks Meter: 21
try to flash w/ higher version
Old 01-08-2009, 23:40   #10 (permalink)
Member: 90377
Thanks Meter: 3
always the first step is to flash your phone with 6.01 sw or higher
Old 01-09-2009, 07:07   #11 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
yes yes TAHVO make this problem
change this ic
post result
Old 01-11-2009, 20:55   #12 (permalink)
webiso's Avatar
Member: 10580
Thanks Meter: 43
change this ic
post result
yes true l try 1 minute ago and okay my phone is working
Old 05-07-2009, 10:00   #13 (permalink)
Member: 138762
Sonork: INFRACTION<=>SICK?
Thanks Meter: 52
first of all rehot display ics with good flaux,if not then rehot all small crystal ics with good flux..if still same then change TAHVO ic..100% solution...not software fault..
Old 05-16-2009, 09:22   #14 (permalink)
Member: 109294
Thanks Meter: 22
Rehot CPU
Hi all! In this case, for me only CPU reheating helped. Reheating Power Source ICs didn't solve "only blue light" problem in my case. (Phone was dropped)
Regards
The Following User Says Thank You to gsmgsa For This Useful Post:
Old 05-19-2010, 07:21   #15 (permalink)
Member: 712690
Thanks Meter: 6
not working 4 meeeeeeeeee
6300 only side blue light only !!!!!! msantar Nokia Hardware & Hardware Repair 28 07-10-2012 05:19
nokia 6300 strange blue lights problem. need help. rk_grover77 Nokia Hardware & Hardware Repair 11 01-15-2010 00:29
6300 when open blue light only ssshsss Nokia Hardware & Hardware Repair 0 07-31-2009 05:39
nokia 6300 blue light only any idea ? aleem26 Nokia Hardware & Hardware Repair 0 02-01-2009 18:13
6300 Blue lights only freewaycomms MT-BOX 14 08-29-2007 16:54
Page generated in 0.32787 seconds with 10 queries
