01-06-2009, 15:49 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 37
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | nokia 7610 flashing problem i flash on the ufs5 version 7.0642 and flashing is ok but uisetting falled i set full factory defaults reset user lock lnit simlock that ok but i on the set that is the show phone start up falled.contact the retaller plz help me that is this problem and his soultion plz |
01-07-2009, 10:57 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | first manual format the phone using * + 3 + call button press together & power on the phone if same after this you should erase flash with erase file & full flash the phone with good pm & do complete ui settings , I think your problem solve then , post result |
01-07-2009, 11:31 | #5 (permalink) | |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | Quote:
its not work brother set is the on and show the connect the retelaer | |
01-07-2009, 12:23 | #7 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india
Member: 581178 Status: Offline Thanks Meter: 438 | first manual format the phone using * + 3 + call button press together & power on the phone if same after this you should erase flash with erase file & full flash the phone with good pm & do complete ui settings , I think your problem solve then not solv ur problem?????????? write rpl................... |
01-07-2009, 16:24 | #8 (permalink) | |
lpz send me erase file and good pm fils adnavce thanks..plz | |
01-07-2009, 18:33 | #9 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 706300 Status: Offline Thanks Meter: 147 | " bro do as RATHNAMOBILESS has written if the contact retailer will appear again after '*3callon', then try format user area option & if result not satisfactory then go for the step as mentioned by RATHNAMOBILESS i.e, erase & flash only,thanx" |
01-08-2009, 13:20 | #12 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: PAKISTAN MARDAN Age: 39
Member: 724090 Status: Offline Sonork: 100.1601663 Thanks Meter: 88 | Quote:
bro . first full erase & after full flash with the up verison u r problem will be solved | |
01-08-2009, 14:34 | #13 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Medan - Indonesia Age: 43
Member: 233686 Status: Offline Thanks Meter: 50 | Quote:
1. full erase the phone.....or erase with erase.fia file.... 2. flash with last version 3. write a good pm 4. fullfactory reset 5. unlock 6. format user area...... | |
Nokia 7610 flash problem | Palash Telecom_ctg | Nokia Hardware & Hardware Repair | 0 | 02-15-2010 13:01 |
nokia 7610 flash problem | touhid007 | Nokia Hardware & Hardware Repair | 1 | 07-30-2009 17:49 |
nokia 7610 flashing problem | saqi160 | Nokia Hardware & Hardware Repair | 6 | 07-26-2009 16:44 |
Nokia 7610 flashing problem | Louie_qrv | Nokia Hardware & Hardware Repair | 5 | 02-04-2007 19:39 |
nokia 7610 flashing problem | systemworm | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 04-17-2005 03:59 |
