11-19-2003, 02:59 | #1 (permalink) |
Freak Poster Join Date: Nov 2000 Location: Croatia Age: 47
Member: 2466 Status: Offline Thanks Meter: 10 | 7110 show charging without charger Does anybady knows solution for this problem? |
11-19-2003, 13:15 | #2 (permalink) |
Major Poster Join Date: Dec 1999 Location: Prague
Member: 764 Status: Offline Thanks Meter: 0 | look for water damage near charging connector. If not remove charging IC and try it if it shows again charging, if not replace it. Next you can reflow ccont(if you see oxid near ccont). This problem is mainly caused by some short circuit on system board. It could be also resistor or capacitor, but it will be 100% near charging IC, try to find some oxid damage. |
11-20-2003, 01:31 | #4 (permalink) |
Member: 2466 Status: Offline Thanks Meter: 10 | I reflowed whole pcb and when charger is connected on phone without battery I measured voltages on all pins of charging IC and all values are the same like on working phone. I think it is not charging ICproblem |
11-20-2003, 02:08 | #5 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | 1st clean the board carefully , also check the charging limit control pin( the 3rd in the charging socket) . Check resistors(R103=47k & R104=4k7),they'r voltage deviders carying voltage of charging to ccont, also check (R102=0.22ohm), It is the charging current sensor. If all is not OK try to reflow the ccont for power meter pin and also the cobba for charging limit data control pin. And Good luck Br. |
11-20-2003, 11:00 | #6 (permalink) |
Member: 764 Status: Offline Thanks Meter: 0 | And what about the voltage value on charging pin on connector? When you remove charger is it dropping down? I had this problem on 6210, but I can not remember the solution. P.S. do fullflash (MCU+PPM+EEPROM) + factory set (If you can set back contrast), just do it for sure |
samsung c100 always shows charging without charger connected | kanewilliam | Samsung Hardware Repair | 0 | 04-25-2008 11:33 |
2618 showing charging without charger | japie | Old Ericsson Phones & Sony Phones | 7 | 02-09-2004 23:19 |
T20S show charging without charger conected?!? | jivkobg | Sony Ericsson Hardware Repair | 6 | 07-26-2002 00:48 |
t10 shows charging without charger | doctorvatson | Sony Ericsson Hardware Repair | 2 | 07-12-2002 13:34 |
7110 shows charging without charger | Saulyss | Nokia Hardware & Hardware Repair | 1 | 06-06-2002 09:22 |
