Old 05-11-2010, 09:13   #1 (permalink)
Member: 405361
Thanks Meter: 13
7210c
sir i have a nokia 7210c it is battery running olnly half an hour pls help me what should i do
regards
shammysaini
Old 05-11-2010, 12:45   #2 (permalink)
Member: 405361
Thanks Meter: 13
pls help me its urgent
Old 05-11-2010, 12:50   #3 (permalink)
Member: 199814
Thanks Meter: 1,960
Mobile is short.. i think
Old 05-11-2010, 13:38   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
change betty ic only
u get good result
Old 05-11-2010, 13:43   #5 (permalink)
Member: 387116
Sonork: 100.1650000
Thanks Meter: 176
1---------change battery
2---------cgange charger
Old 05-14-2010, 12:45   #6 (permalink)
Member: 405361
Thanks Meter: 13
sir i have also changed the orginal battery & charger and 2nd thing my mobile is not short
Old 05-17-2010, 07:39   #7 (permalink)
Member: 405361
Thanks Meter: 13
sir pls help me my nokia 7210c battery is running only half an hour ........ and mobile is not short ................. and not water damage ............
Old 05-17-2010, 08:25   #8 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
short ur centre(battery terminal) pin direct to ground and check
Old 05-18-2010, 08:41   #9 (permalink)
Member: 387116
Sonork: 100.1650000
Thanks Meter: 176
remove v2000 -----------------------
Old 05-18-2010, 08:45   #10 (permalink)
Registered User
Member: 536592
Thanks Meter: 210
change battery ic your problem will be solved
Old 05-18-2010, 08:52   #11 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
the fault in batteryy ic change it or may be its liquid damege the board and clean it with ctc and rehot normaly
Asghar Hussain
movilsat centro tecnologico
MovilSat
Old 05-24-2010, 09:06   #12 (permalink)
Member: 405361
Thanks Meter: 13
where is battery ic pls show me ...............
Old 05-24-2010, 09:51   #13 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
where is the battery ic mate's ?? I can't find in schematics.....................
to shammysaini remove bluetooth ic & check , many times tested by me
post result
Old 05-24-2010, 13:42   #14 (permalink)
Member: 328187
Thanks Meter: 1,687
NOKIA 7210C BETTY IC
Old 06-07-2010, 12:20   #15 (permalink)
Member: 405361
Thanks Meter: 13
i think scsacar is right good work ...........
n91_2 /7210c mediaset33 J.A.F. By Jafsupport.com 2 11-24-2008 14:50
Compatible Nokia 7210c Dummy Phone IPMART ipmart WebShop 0 10-25-2008 08:50
Cable (10Pin) Compatible For Nokia 7210C For MT Box IPMART ipmart WebShop 1 09-20-2008 08:57
Cable Compatible For Nokia 7210C For JAF / UFS HWK IPMART ipmart WebShop 0 09-20-2008 08:00
Nokia 7210c Dummy Phone - Original IPMART ipmart WebShop 0 09-05-2008 12:36
Page generated in 0.24410 seconds with 10 queries
