08-22-2001, 03:43 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | 3310 charging problems -- what I meant was that, charging does not stop even when the battery (i think) is already full. On top of that.. another anomaly is that the time was halted when the charger was plugged in. I just found that out this morning when I looked at the time. When charger is unplugged, time display is normal. Got any suggestions m8s? [ 22 August 2001: Message edited by: Hanukkah ]</p> |
05-18-2005, 14:52 | #2 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Berlin Age: 60
Member: 90804 Status: Offline Thanks Meter: 46 | 3310 not gharging. Nothing happens if charger is connected. Check mechanical appearance of bottom-connector. 1. Check resistance of F200 & L202. 2. Check resistance of Vcharge-line to ground, value should be around 50kOhm. If not ok check/change V201,C215-217, N200. "Not charging" appears on LCD Run energy management calibration. If it works without failuremessages, try to charge after calibration. Battery temperature failed : 3. Check X203, R220/222, if not OK, change CCONT N201. Battery size failed : 4. Check X203, R220/222 or change CCONT N201. Battery voltage failed : 5. Change CCONT N201. Charge current failed : 6. Chaeck/change R204, N200, N201. Charge voltage failed : 7. Check Vcharge at voltage-divider R209/210. If ok, change CCONT N201. 8. If not ok, check parts like X200, V201, F200, L202 or change N200. goodluck. gsmarmoon |
05-18-2005, 14:57 | #3 (permalink) |
Member: 90804 Status: Offline Thanks Meter: 46 | 3310 Notgharging. Nothing happens if charger is connected. Check mechanical appearance of bottom-connector. 1. Check resistance of F200 & L202. 2. Check resistance of Vcharge-line to ground, value should be around 50kOhm. If not ok check/change V201,C215-217, N200. "Not charging" appears on LCD Run energy management calibration. If it works without failuremessages, try to charge after calibration. Battery temperature failed : 3. Check X203, R220/222, if not OK, change CCONT N201. Battery size failed : 4. Check X203, R220/222 or change CCONT N201. Battery voltage failed : 5. Change CCONT N201. Charge current failed : 6. Chaeck/change R204, N200, N201. Charge voltage failed : 7. Check Vcharge at voltage-divider R209/210. If ok, change CCONT N201. 8. If not ok, check parts like X200, V201, F200, L202 or change N200. |
3310 Charging problem | Vicky | Nokia Hardware & Hardware Repair | 5 | 10-14-2004 18:59 |
3310 charging problem | SubTen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-18-2001 09:37 |
3310 charge problem | gsm-lord | Nokia Hardware & Hardware Repair | 7 | 11-26-2001 15:38 |
3310 charging problem | garcea10ro | Nokia Hardware & Hardware Repair | 2 | 10-24-2001 16:07 |
3310 charging problem | pornopig | Nokia Hardware & Hardware Repair | 5 | 10-08-2001 20:37 |
