09-25-2008, 17:30 | #1 (permalink) |
Junior Member Join Date: Jun 2008
Member: 801104 Status: Offline Sonork: jeeva Thanks Meter: 0 | 7610 dead Default SN type: p????????????????????????????? LOG IS HERE HELP ENEYBODY Getting MCU ID MCU ID: 0x1081 FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 6.0522.0 02-06-05 RH-51 (c)NMP HW version: 7029 PCI version: UEM version: 144 UPP version: 4225 RFIC version: 0205 DSP version: CN5.10 PPM version: V 6.0522.0 02-06-05 RH-51 (c)NMP.03 BT MCM version: Production serial number: PEL390988 Product code: 0514537 Module code: 0202215 Basic production code: 0528496 Flash code: Order number: Product specific data: Long production SN: ATO: p????????????????????????????????????????????????? Default SN type: p????????????????????????????????????????????????? IMEI plain: 358390008540539 IMEI spare to net: 3A 85 93 00 80 45 50 03 IMEI SV to net: 33 85 93 00 80 45 50 33 F0 PDC: 4E 54 54 4A 50 12 34 56 Master Code: 0646017104 Phone type: RH-51, Software version: 6.0522.0, Language Pack: 03 User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0514537 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.03 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,French (Arabic) Done! |
09-25-2008, 20:07 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | when IMEI shown ??????? your mobile will temporaly blinking/restricted it comes from bad security on your phone. it can be normally if you can repair phone IMEI. how to repair IMEI on Nokia DCT4/WD-2 Phone ?? 1. Software If you use JAF box Read Ask data and send to the server that can calculate your phone (GTI Server/Mxlogger server/Fufenu server) <-- Each server have a program that can calculate it please search... (you should have any credit if your ask want to calculate) after you have an ask data and send to the server, the server will calculate your IMEI and reply with rpl data. send rpl data to your phone and do not forget to unlock it after rpl written. 2. Hardware change UEM IC and write Rpl file (you can use another rpl from other same phone) but your IMEI will not same as with your IMEI as shown on your back case. if you want to back your past IMEI do the instruction on No. 1 Regards |
7610 Dead-flashing Ok-in It Local Mode Failed-replaced Uem-still Dead | zonetrichur | Nokia Hardware & Hardware Repair | 26 | 03-27-2010 08:06 |
7610 dead,flashing ok,still dead | Vcell | WD2 & APE (Symbian Phones) | 2 | 08-10-2008 11:57 |
7610 dead | dogandbone | Twisterflasher | 4 | 12-07-2005 14:54 |
7610 dead | techman | Nokia Hardware & Hardware Repair | 6 | 12-06-2004 09:59 |
nokia 7610 dead | ray_5572 | WD2 & APE (Symbian Phones) | 4 | 11-11-2004 06:37 |
