06-02-2008, 09:05 | #1 (permalink) |
Insane Poster Join Date: Apr 2005 Age: 48
Member: 138236 Status: Offline Thanks Meter: 10 | 7610 error! Full erase. full flash. format with *+3+send key+power on. .......................................... MCU ID: 0x1081 Boot is ready... Algo is ready... Loader is ready... Erasing area: 00000000 - 00FFFFFF... Done! Erasing area: 02000000 - 02FFFFFF... Done! Erasing area: 04000000 - 04FFFFFF... Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.02 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,French,German (Euro A) Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.03 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,French (Arabic) Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: ac Loader is ready... P-key nokia module version 01.02 MSID: 84B14D4DF689CC83C6434862FF MSID decoded: 3E4EBAF700C5A221A9000000 FAID: 65E0739D794ECD8043CDF8FB Operation took 0 minutes 37 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 00FFFFFF... Erasing area: 02000000 - 0287FFFF... Erasing area: 02FC0000 - 02FEFFFF... Operation took 4 minutes 28 seconds... Writing... Perm. Data Restore OK Operation took 4 minutes 24 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.03 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7F10; Loader chk: ac Loader is ready... P-key nokia module version 01.02 MSID: 84CB312FB3DD37B9C0BAF8A4B6 MSID decoded: 3E4EBAF700C5A221AA000000 FAID: C5BCEB21503318F6115F284E Operation took 0 minutes 26 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02A00000 - 02CAFFFF... Operation took 0 minutes 26 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 23 seconds... Restarting MCU... Flashing Done! Operation took 11 minutes 36 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-51, Software version: 7.0642.0 IMEI: 355700004053415 Product Code: 0514537 Resetting PPC... Done! .................................................. . but same problem. Help please. |
06-02-2008, 09:09 | #2 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | ==>rashidj first of all this problem happend after wrong flash or u recive the phone with this problem and normal flashing with mcu and ppm not help to repair this problem so do next 1- with ufs box start to erase manual this adress start: 00000000 end: 00FFFFFF start: 02000000 end: 02FFFFFF start: 04000000 end: 047FFFFF this 3 adress will eras the 3 flash's and u will not lost ur phone imei 2- with ufs again erase start: 00010000 end: 0000FFFF start: 02000000 end: 00FFFFFF start: 02FC0000 end: 0286FFFF start: 02A00000 end: 0000FFFF 3- flash ur phone with latest firmware 4- write full pm to ur phone 5- unlock and format user area |
06-03-2008, 07:27 | #3 (permalink) | |
Member: 138236 Status: Offline Thanks Meter: 10 | Quote:
Same error. Any other sulotion plz. | |
7610 Error | SPEEDYSQUIRES | Twisterflasher | 4 | 08-04-2006 23:10 |
help me can not flash 6600 and 7610 error | not mobile | Griffin | 4 | 06-29-2005 15:46 |
nokia 7610 error conection | gbada | Nokia Multimedia | 3 | 11-29-2004 09:23 |
7610 error aftering processing | tommy00 | Griffin | 0 | 10-06-2004 10:24 |
