10-26-2007, 06:41 | #1 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 246691 Status: Offline Thanks Meter: 54 | 7610 screen only appear NOKIA |
10-27-2007, 18:22 | #11 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Punjab, Pakistan Age: 38
Member: 264520 Status: Offline Thanks Meter: 61 | *** FINAL *** 1st erase >> after done flash MCU+PPM with final version >> FORMAT USER AREA >> UI Setting. after all proccess if ur NOKIA LOGO problem still, Format ur fone MANUALY with HOLDE * , 3 , SEND key and power ON. 2nd if problem still Reflow Sdram and 4 flash memory chips. 3rd change Sdram and 4 flash memory chips. post result. |
10-27-2007, 18:55 | #12 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | thats not a boot ic problem (1) at first try flash. (2) scend removed that ic (3) therd re hot rm and flasher....its a solution onley. i have done 8 time all rady......good luck... |
10-27-2007, 20:57 | #13 (permalink) | |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | Quote:
IT IS NOT A BIG TO CHANGE WHEN U KNOW IT IS EASY PROCEDURE THEN WHY U GIVE HIM LENGHTY PROCEDURE .AND ALWAY IF NOKIA STILL ON DISPLAY THAT TIME NO NEED TO ERASE OR FLASH JUST FORMAT THE FONE PROBLEM WILL BE SOLVED, IF NOT THEN GO DIRECT BOOT IC.80% STUCK ON NOKIA IS IN BOOT IC. | |
HELP, 6120c on appear nokia moment, then appear blue screen ..... | TANGINGSIANG | Nokia Hardware & Hardware Repair | 9 | 02-25-2010 14:42 |
5300 on appear nokia all the time .....only | TANGINGSIANG | Nokia Hardware & Hardware Repair | 7 | 07-10-2009 14:12 |
ce110 simlocks disable screen appears i need subsidy code screen to appear | maxheadquarters | LG | 0 | 09-19-2008 22:29 |
7610 start up appear only " NOKIA" ? | eng.hamdow | Nokia Hardware & Hardware Repair | 45 | 04-18-2008 02:49 |
7610 screen no appear | acelai00 | Nokia Hardware & Hardware Repair | 2 | 03-14-2007 15:08 |
