11-29-2007, 22:35 | #31 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | 7610 start up appear only " NOKIA did you try allrady so many solution now check my solution ... see the picture and remove that ic and clane pcb and witch side uem flasher ram that site keep the table lamp hit 30 munite and need to cool 2/3 minet now check set will be ok....good luck..... sopnil |
The Following 2 Users Say Thank You to sopnil For This Useful Post: |
12-02-2007, 11:05 | #32 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi all.. i have been changed all boot ic and another ics.. phone was on contact service... after format user area phon only shows nokia on startup.. is there any other solution..? thanx.. Last edited by LoveLess; 12-02-2007 at 11:12. |
12-02-2007, 15:56 | #37 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | yes brthr if u have flash ur phone with latest ver then after flashing if problem is same then it must have problem in hardware.... so do haredware brthr.....if u have reball uem yhen try to check with another uem or change it... if not solve then the fault also may in flash ic reball them.......good luck... |
12-02-2007, 16:05 | #38 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
uem + flash ics were working other pcb.. i think uem + flash ics nice. but maybe upp or ram can be fault..? | |
12-02-2007, 16:11 | #39 (permalink) |
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | yes brthr u have to change both flash and uem frm other set........if u want to change only uem then u have to change it with blank one then u have to wrte rpl file o asic -5 godd luck..... |
7610 start up failer | burraq | WD2 & APE (Symbian Phones) | 12 | 04-18-2009 18:02 |
E90 FLASH but DISPLAY ONLY " NOKIA" | denard | HWK | 9 | 07-05-2008 17:37 |
7610 start up fail | amitks_in | Nokia Hardware & Hardware Repair | 11 | 09-04-2006 10:36 |
7610 start-up failed affter 30min pwoer off | ashrafcell | Nokia Hardware & Hardware Repair | 6 | 06-11-2006 09:50 |
7610 start-up fail | kenichi | Twisterflasher | 7 | 07-16-2005 15:19 |
