7650 cannot detect charger my 7650 cannot detect a charger can you give me an idea on how I taced the cause. I Plug the charger and I test the volt output to the terminal there is on 0.4 volts output going to the battery. thanks for your help.:) |
your problem may be the fuse...... u must use a multimeter with buzzer...and chech for continuity .... so if you dont know where is located ..use the buzzer starting from the charging connector (+) ...and check all the small components looking like an resistor ... usually the fuse is white (somketimes there is a "k" letter on it ) REGARDS |
Change the flex ribbon, i have the same problem, change the ribbon, the phone can detect the charger. BR Unggul |
-at first check fuse on grip module -check diode on grip module -check Flex foil, if broken change it -check also uem and aem B.R. desperado |
