09-17-2002, 23:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Portugal- Center of Europe Age: 42
Member: 9502 Status: Offline Thanks Meter: 9 | 8210 problem where? |
09-19-2002, 00:56 | #5 (permalink) |
Insane Poster Join Date: Jul 2002 Location: Egypt Age: 45
Member: 14194 Status: Offline Thanks Meter: 4 | Hi sergioems 1)Try to clean the card connector on the board and the battry connector on the board- of course you changed the back cover so you changed the simcard connector and the battry connector ***If not help then go to step 2 2) Chang another pa ***If not help then go to step 3 3) Rehot or chang the ccobba ***If not help then go to step 4 4) Rehot or chang the ccont ***If not help then go to step 5 5) Rehot or chang the hagar ***If not help then go to step 6 6) Sorry chang your phone goodluck Wesam |
09-19-2002, 22:07 | #8 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | Hi, - You can try to reflow the phone, because pure connection can endure this things. - D'ont forget to make out all mecanical problem, related with connectors, with screw,... Test the PA output and power consumption, may be you chould to replace a good PA. Check also CCONT Good luck |
09-19-2002, 23:01 | #9 (permalink) |
Member: 9502 Status: Offline Thanks Meter: 9 | ok willy but tell me on more thing. about wintesla i hasn't able to put it working on my computer. tell me this once i've changed the pa and the sintoms have changed it should be no longer pa problems right? reply me please! |
09-20-2002, 13:14 | #10 (permalink) |
Member: 9502 Status: Offline Thanks Meter: 9 | now the 8210 i've tested today and is having the same problem that is make a call after 5 seconds batery down and go off. what do you sugest?. change pa again or change hagar first? or reflow only? reply. thanks |
09-20-2002, 22:18 | #11 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Sergioems., that battery is working at others phone ? if yes, then you try to change C165, and Vtx at C154 ! and without wintesla,, you can not to measure phone well ! fix a 3210 same problem with you , just by correct TX output level by wintesla Willy Quote:
8210 problem. problem and problem | Unggul | Nokia Hardware & Hardware Repair | 6 | 03-28-2005 21:56 |
8210 f101-where to link too? | Dave.W | Nokia Hardware & Hardware Repair | 4 | 04-17-2003 22:13 |
8210 problem.Help please | GreEn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 02-18-2001 14:29 |
Micron MT28F160C3-T, ALIAS_ID=008988C2 / 8210 problem | FunLog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-02-2001 02:44 |
nokia 8210 problem | S-max | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-26-2000 17:14 |
