Old 08-25-2003, 15:40   #1 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
Unhappy charging problem:(
Hi Guys,
Normally 3.5V to charge the battery on the terminals. BUT.....
i have liquid damaged (little) , 8210 have charging problems,
first i measure both terminals (0v) with AC charger plug on,
i check all the charge input lines all fine.
then i changeg CCONT , now i have (2.59V) on terminals.. so i moved on to replaced N200, still (2.59V) out..
i have try flashed, but still..
any ideas guys??
regards
TMPC
Old 08-27-2003, 00:21   #2 (permalink)
Member: 24581
Thanks Meter: 87
do you reball or change 4370567-charging ic?what is the resistance betwen + and - charging pin?check do you have short circuit betwen +of batery on PCB and o.22ohm resistor near conector fotr charging?sory for my wery,wery bad language.
Old 08-27-2003, 06:42   #3 (permalink)
Member: 23372
Thanks Meter: 18
try to change charging ic if the problem is the same change ccont
Old 08-27-2003, 13:32   #4 (permalink)
Member: 20639
Thanks Meter: 233
hi, jln310
already change charging ic and ccont as above message..
thanks
samsung e330 problem charge? cerimobil Samsung Hardware Repair 1 08-01-2012 10:40
USB-Smart Problem:( Afzaal SonyEricsson (USB-Smart) 1 02-19-2006 14:10
nokia 6610i lcd problem:( OncleOh Nokia Hardware & Hardware Repair 9 07-20-2005 01:10
E398 Trans flasch adapter problem:( Best_Gsm Motorola P2k 0 02-19-2005 14:50
7110 phone book problem:( aklishin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 04-17-2001 20:33
Page generated in 0.16876 seconds with 9 queries
