8310 damaged power switch I have a 8310 that has the "pcb damaged" on the place where should be the pads too solder this switch on.. 1 pad ok other damaged. Any ideaa where I can wire too to make it work? Left pad is ok rgds GsMen |
Right pad is connect to the left pad so you can make connection between them directly |
:D :D I understand but there is NO right pad.... ...So I want to make a wire from "where should be right pad too xxxxxx..... ....I need to know xxxx :D |
one side to GND, and others to xxxx, this xxxx=R301 and it near UPP ! Willy |
but unfortunally it doesnt work :-((( R u sure it is R301 ? GsMen |
<p><A href="http://imagehost.auctionwatch.com/bin/viewimage.x/00000000/demetan1/8310_pwonx.jpg"><img src="http://imagehost.auctionwatch.com/bin/imageserver.x/00000000/demetan1/.mids/8310_pwonx.jpg" </font></A><br> willy |
@willy do you have a proper service manual for the 8310 please mate. i am interested in all nokia service manuals.sadly lots of them on the net are to basic. many thanx [email protected] |
goto laundy site for servicemanuals also 8310 |
Gsman, So your 8310 can power up already ? did you test what voltage is in R301 when you put battery ? Willy Quote:
@willy I also have same problem. I have no 8310 service manual. Can you please point me in right direction to obtain 8310 service manual. I need to find R301. Or alternatively if you can take photo of board and mark r301. i think this would be a great help not only to me but to all members |
Re: @willy ali-g-string it beside UPP,, between UPP to Key connector ! i am in vacation now,, i will back on 31th DEC,i will try to upload a photo here after 31th! Willy Quote:
Thank you Willy I now have the service manual, so problem resolved. Thanks for your help |
I have the same problem with a 5210. I've lost the bottom pads on both sides of the power switch. Where should I bridge to? I don't have a service manual. |
HI dubundrums Did you manage to repair the 5210. I too have 5210 with pads missing. Please can you or WILLY help me. The earth side is Ok the other two pads are missing. Where on board can I attach a wire. |
On 5210, power switch is connected paralell to C342. C342 is nearest element to PWR switch! |
