8310 dead after dropped on ground please help!! 8310 won't power on... how to fix this problem? thanks |
Re: 8310 dead after dropped on ground Ryu, Check all system clock, if 26Mhz and 32.768khz all ok then you have to reball flash rom , and flash phone ! Willy Quote:
There is of course a possibility that the Power IC has become dry contact after the fall...do this.... Without LCD ..try to switch on the set applying pressure to the power ic...if it does not switch on ..then try twisting the PCB a little and pressing the power button at the same time:))) if the set switches on ..then you are confirmed that the Pow IC is dry and you can re-flow. |
thanks all! :) let me try all solutions. |
