Old 08-21-2004, 20:12   #1 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
8310 no respond for charging
Did any body have or know solutions to repairer Nokia 8310 no respond for charging?????????? when I connect charger and I check with multitester the connector battery 0v.
thanks for help and info and so sorry for my bad english.
regards,
uwenk98
Old 08-21-2004, 20:32   #2 (permalink)
Member: 45373
Thanks Meter: 3
check this, I found it many time broken
Old 08-23-2004, 01:22   #3 (permalink)
Member: 4249
Thanks Meter: 2
1- check the charging fuse.
2- check the charging diode beside the fuse.
3- rehot UEM with good flux
4- change UEM
I wish that everything is clear now
Old 08-23-2004, 21:19   #4 (permalink)
gibso's Avatar
Member: 25150
Thanks Meter: 8
mimover has it all follow those steps & you'll be ok
gibso
Old 08-23-2004, 21:20   #5 (permalink)
gibso's Avatar
Member: 25150
Thanks Meter: 8
hey dont forget to make sure that the pins of the charging pot is clean & contacting well on the PCB
Old 08-23-2004, 21:31   #6 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
08-22-2004 I change the fuse, I put it from dead 8250 and charging work normal again thanks for all help my friend specially to my friend Mr.Vrem thanks a lot.
regards,
uwenk98
Old 08-24-2004, 02:01   #7 (permalink)
Member: 4249
Thanks Meter: 2
by the way you can remove the fuse and connect a wire instead of it and everything will be ok..this if you didn't find onther fuse.
the function of the fuse in the circuit is to protect the charging circuit from sudden rise in voltage which will damage the UEM and other component.
br
MT 6225 No Responese for Charging...Help cpu_man07 SpiderMan 0 10-23-2009 18:00
Motorola V6 Not charging/No respond andrew14 Motorola Hardware Repair 1 09-29-2009 08:05
problem with gsmfather (pay but no responde for credits) crys_justus Gsmfather The Wholesale Unlocking Database 6 07-16-2009 13:55
8310 no power on but charge Cat10 Nokia Hardware & Hardware Repair 7 09-10-2004 18:02
flashing 8310 - No Loader for this flash or model! sat Nokia Digital Core Technology 4 ( DCT-4 ) 14 01-24-2003 11:12
Page generated in 0.19186 seconds with 10 queries
