07-10-2003, 19:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | 8310 power button track,ripped of,help plz i have a 8310 power button track ripped off,only left track is there,the right on is totally ripped off,couls some 1 plz help me n tell me where it leads to, and if it would be possibe to repair,pic is possible thanks alot bye |
07-10-2003, 19:20 | #2 (permalink) |
Junior Member Join Date: Mar 2002
Member: 9823 Status: Offline Thanks Meter: 0 | right track .. hmmm connect to ground and all will be good. If it is the other track find R301 and connect to that. IIRC ( prolly not as i am tired) Please correct me if i am wrong anyone |
07-10-2003, 19:34 | #3 (permalink) |
Junior Member Join Date: May 2003 Location: Sussex Age: 66
Member: 28964 Status: Offline Thanks Meter: 0 | I have repaired quite a few with the same problem successfully. Left hand side is earth/ground, as you have broken the right hand side then run a wire from the switch to c312. This info was supplied to me by excelldirect (www.excelldirect.co.uk). Although I have not yet tried it, according to excell you can even repair a switch with no pads on the board. They recommend gluing the switch to the board with super glue running a wire to ground and one to C312. Again I have never tried replacing "both" broken legs but I have a friend who has and he says it works every time. I would also advise gluing the switch even with only one leg broken as a switch needs a fair amount of strength from heavy handed users Fuse |
I-phone 3g cannot turn off even if u press power button and also noservice help!!! | ARAB GSM | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 09-28-2009 21:49 |
N95 rm-159 power off after 4h of time plz help | ORACHI | Nokia Hardware & Hardware Repair | 0 | 09-08-2009 15:03 |
rage rd220 no on i will press power button display blinking please help me | prakash40 | Chinese Models & Cloned Phones | 1 | 09-05-2009 17:17 |
T-610 Power Button track and joystick points | moienshah | Sony Ericsson Hardware Repair | 2 | 03-30-2008 20:04 |
8310 track off power button?? | YeTi | Nokia Hardware & Hardware Repair | 5 | 03-11-2004 23:54 |
