12-16-2005, 09:33 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 48
Member: 64744 Status: Offline Thanks Meter: 14 | 8800 power problem I have here one brand new 8800 and have one strange prob. The problem is that the phone is working until the battery is showing 4 lines when the battery drop to3 lines the the phone cant make phone calls is shutting off. I try the phone with a new battery and the prob exist i also flash the phone with the latest version but no result. Can enybody help me about this prob?? Thank you |
12-17-2005, 22:59 | #3 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Egypt Age: 44
Member: 51609 Status: Offline Thanks Meter: 6 | maby ur problem is up to uem that nead to chang yes it's brand new phone but this not mean it's hardware is ok some pcb have fult's and maby ur phone is one of this fulty phone's |
12-18-2005, 02:38 | #4 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | first at all check consumation of phone when register to network and when you call someboddy if all is ok posibly PM problem........erase phone then full flash phone mcu+ppm+cnt+pm unlock phone.........check when phone is on charger get some consumation from charger?test this and if all is ok then your problem is big - UEM |
01-31-2006, 17:31 | #8 (permalink) |
Insane Poster Join Date: Apr 2004 Age: 48
Member: 60779 Status: Offline Thanks Meter: 0 | Same problem here, any solution? Well I've got the same problem here. Did you guys find any suitable solution? I know these phones have short battery life, but dropping all of a sudden from 4 to zero is quite more tricky than a "short battery life". I haven't tried with an other battery though, but I think I'll get the same results. Maybe manufacturer's origin defect? Hope u guys found a solution. If u did, please share it with us. |
01-31-2006, 20:41 | #9 (permalink) | |
Freak Poster Join Date: Dec 2005 Age: 44
Member: 214350 Status: Offline Thanks Meter: 17 | Quote:
8800 charge problem | jak2812 | Nokia Hardware & Hardware Repair | 18 | 03-13-2010 13:38 |
8800 power way need | CHANDARAKK | Nokia Hardware & Hardware Repair | 0 | 01-12-2010 06:03 |
8800 power ic jumper needed? | technicservice | Nokia Hardware & Hardware Repair | 3 | 08-21-2008 15:32 |
nokia 8800 power drain quickly | cjohnjohn | Nokia Hardware & Hardware Repair | 5 | 07-09-2007 07:08 |
8800 power off | tcdxb | Nokia Base Band 5 ( BB-5 ) | 2 | 11-16-2006 17:23 |
