06-10-2002, 14:33 | #1 (permalink) |
Junior Member Join Date: May 2000 Location: U.K
Member: 1476 Status: Offline Thanks Meter: 0 | 8850 no recetion after being hit on the wall I got an 8850 that gives 10 seconds of reception each time it is switched on. after that the reception drops. It is 1000% a hardware fault. I hear that changing the PA might do the trick. Plz can some 1 verify if this is the right thing to do. If so what does the PA look like?? does it have chip number?? thanks Max p.s. Also I have 3210 not charging. Any ideas?? Thanks. |
Auto select the firmware can only be installed on the Phoenix product folder?[SOLVED] | ken6430841 | Cyclonebox | 10 | 11-16-2009 09:01 |
Can the phone be unlocked on the weekend? | gabnic | D-Unlock Suite | 0 | 08-02-2008 10:38 |
Can the OK shortcut be changed on the D900i | cuddlezuk | Samsung Flashers, Software, Firmware. | 0 | 03-02-2008 11:19 |
need to be access on the server | thiam | Redbox | 0 | 04-24-2006 01:56 |
