Old 05-28-2004, 08:22   #1 (permalink)
Member: 63385
Thanks Meter: 3
Exclamation [B]3510 displays "NOT CHARGING!"[/B]
Wat to do wid 3510 "NOT CHARGING"... I have change the Battery Terminal already...
Old 05-28-2004, 14:29   #2 (permalink)
Member: 66961
Thanks Meter: 2
you need to open the phone and check the small ziener diode (small black thing near to the connector ) with 3510 comming without soldring from nokia if so ..the problem in the UEM and no one can help ......
Old 05-28-2004, 17:21   #3 (permalink)
Member: 63385
Thanks Meter: 3
Wat connector?... Specify pls. Thanx!
merulez29
Old 05-28-2004, 20:10   #4 (permalink)
Member: 66961
Thanks Meter: 2
i mean charger connector end of the pcb bord
Old 05-28-2004, 20:18   #5 (permalink)
Member: 39601
Thanks Meter: 13
OK .... Check R200 , if it is good , try PM file and phone resetting , if problem is still . no way its the UEM !!!
Regards
Old 08-04-2006, 12:15   #6 (permalink)
BalfourCellular's Avatar
Member: 86981
Thanks Meter: 10
slighly re heat UEM DONT COOK IT !!!!!!!!!!!!!!!!!!
6230 "not charging..." very strange Byte Nokia Hardware & Hardware Repair 4 03-01-2007 22:07
3510 says "not charging" bogym Nokia Digital Core Technology 4 ( DCT-4 ) 11 08-04-2006 12:09
please, nokia 6600 " no display on lcd " ? eng.hamdow Nokia Hardware & Hardware Repair 2 10-07-2005 14:32
Sagem MW3026 displaying "3" then "!" gn71 Infineon C16X M51 & ARM7 M52 BASED 1 06-01-2005 01:27
7650 - "Not allowed!" Ammonit Phone Unlocking Codes & Maps 2 02-15-2003 21:44
Page generated in 0.16561 seconds with 9 queries
