06-13-2009, 22:34 | #1 (permalink) |
Junior Member Join Date: Dec 2008
Member: 929079 Status: Offline Sonork: Dpking Thanks Meter: 2 | ..::Backup 308 Failed::.. is it jaf always need the phone 100% ok? if yes than no one should buy the box!!! any idea??? any solution for my question?? |
06-14-2009, 07:33 | #4 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
if ur set will not come in local mode then it will not take backup ... posiible reason of phone not coming in local mode .... 1..check conection or ur fbus cable ... 2..hardware fault...check in hardware ...batery connector ,,tahvo ic ,,retu ic. check bsi track.. 3..software fault ..flash ur phone with proper flash files and with latest ver... in working handest like nokia n95 8gb remove camera then attach it with fbus cable and then ur set will proper come in local mode ... | |
..::7210c contact service simlock failed::.. | HUM | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 02-04-2010 11:08 |
.::i850 Message sending Failed::. :( | azeem781986 | NSPRO | 0 | 09-18-2009 19:24 |
..::8800 camera operation failed::.. | HUM | Nokia Hardware & Hardware Repair | 7 | 07-12-2009 17:08 |
..::6600 flashing complete but ui failed::.. | HUM | Nokia Hardware & Hardware Repair | 21 | 03-17-2009 18:22 |
