Old 08-12-2002, 17:22   #1 (permalink)
cris's Avatar
Member: 2375
Thanks Meter: 4
Startup problem with NOKIA
I have problems with some Nokia terminals (6210, 8210) about s tart-up. If I use normal and full battery the phones DO NOT start-up. But if I use an extermal power supply like dummy battery the phones work normaly. For dummy battery I use Ubat + 1volt (3.6 + 1 = 4.6Volts).
I replaced charging IC, CCONT IC and COBBA IC... But no results
Have anybody a solution for this?
Thanks in advance!
Old 08-12-2002, 20:27   #2 (permalink)
george gsm's Avatar
Member: 14200
Sonork: Sonork id
Thanks Meter: 117
hello cris,
i'm not sure but change the flash
geo
Old 08-13-2002, 09:23   #3 (permalink)
cris's Avatar
Member: 2375
Thanks Meter: 4
Hi George,
I tried to replace flash IC to other phone, rewrite it, but after this the phone swiched down in 5-10sec. I don`t now, maybe it`s not corectly replaced...
Old 08-13-2002, 22:42   #4 (permalink)
Member: 1060
Thanks Meter: 10
Re: Startup problem with NOKIA
Cris,
you can do this.
Put a resistor 22K ohm, between BSI to GND
then use power supply to VB + and GND
then 4V-4.5V , see phone will power on or not !
Willy
Thanks in advance!
Problem with nokia 5320 with flash ! Unlocker_001 Nokia Base Band 5 ( BB-5 ) 1 03-24-2009 18:49
unlocking problem with nokia 5200 with www.bb5box.org sunnagar Nokia Base Band 5 ( BB-5 ) 2 08-25-2008 19:15
Unlocking problem with Nokia 2610 but not with Nokia 2310 simclub1 MT-BOX 28 03-14-2007 11:26
Can't solve X480 startup problems with NS dongle chrisonic NSPRO 3 05-20-2006 17:44
Battery problem with nokia handset with a proper Sim card Vijay Arora Nokia Digital Core Technology 4 ( DCT-4 ) 2 05-09-2006 06:39
Page generated in 0.19251 seconds with 9 queries
