08-25-2008, 19:00 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: rotterdam ,netherlands
Member: 295890 Status: Offline Sonork: 100.1592876 Thanks Meter: 33 | unlocking problem with nokia 5200 with www.bb5box.org the first mobile went very well ----------------------------------------------------------------------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_03.70_22-09-06_RM-174_(c)_Nokia. IMEI: 35000000000000000000000 SP LOCK status: Config Key: 7161000000000000 Block 1: CLOSED Type 5 Data: 71610F Block 2: CLOSED Type 5 Data: 71610F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-174_352733016818478_Locked_Keycnt_0_Fbuscnt_0__V_0 3.70_22-09-06_RM-174_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest counters ... Finded backup file: RM-174_35000000000000000000_Locked_Keycnt_0_Fbuscnt_0 __V_03.70_22-09-06_RM-174_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7161000000000000 Block 1: CLOSED Type 5 Data: 71610F Block 2: CLOSED Type 5 Data: 71610F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7161000000000000 Block 1: OPEN Type 5 Data: 71610F Block 2: OPEN Type 5 Data: 71610F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull ---------------------------------------------------------------- But soon after i tried to unlock the other same mobile ands before that i installed all the flashes but could not unlock even one of those ----------------------------------------------------------------------- Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-174 Version: V_05.53_03-03-08_RM-174_(c)_Nokia. IMEI: 359816018268157 SP LOCK status: Config Key: 2140700000000000 Block 1: CLOSED Type 5 Data: 21407F Block 2: CLOSED Type 5 Data: 21402F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Checking if model/version is supported for unlock ... Model/version NOT supported for FBUS counter reset. Please upgrade or downgrade! Model/version NOT supported for UNLOCK. Please upgrade or downgrade! --------------------------------------------------------------------- i have installed all the flashes and even then i am having the message. can any one guide me what is the problem. thanks in advance |
08-25-2008, 19:14 | #2 (permalink) |
Registered User Join Date: Feb 2006 Location: Ireland / Belarus
Member: 234917 Status: Offline Thanks Meter: 160 | Sunday unlocker The firmware version in this phone is v5.53 which is not supported by this box. You can downgrade the firmware to v5.51 and then unlock. Use a flasher such as JAF which is capable of downgrading BB5 phones. Downloading and installing the flashfiles on your PC is not enough!!! |
The Following User Says Thank You to ronandaly For This Useful Post: |
08-25-2008, 19:15 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | Version: V_05.53_03-03-08_RM-174_(c)_Nokia this version is nt suppoirted for unlock downgrade! to 5.00 version for unlock check list which is supported for unlock 5200 (RM-174) – Flash Chip SEC xxxxxxxx-ATB - Supported ALL versions available today MCU firmware version Nokia Data Package file for flashing V_03.70_22-09-06_RM-174_(c)_Nokia. RM-174_DP20_1.00__sw-03.70.exe V_03.92_13-10-06_RM-174_(c)_Nokia. RM-174_DP20_2.00__sw-03.92.exe V_03.93_20-11-06_RM-174_(c)_Nokia. RM-174_DP20_2.30__sw-03.92.exe V_04.71_28-02-07_RM-174_(c)_Nokia. RM-174_DP20_3.00__sw-04.71.exe V_05.00_27-04-07_RM-174_(c)_Nokia. RM-174_DP20_4.00__sw-05.00.exe V_05.51_05-09-07_RM-174_(c)_Nokia. RM-174_DP20_5.00__sw-05.51.exe |
The Following User Says Thank You to makkah mobile For This Useful Post: |
Problems With Nokia 5200 | Tikytiky | Universalbox | 21 | 07-07-2009 06:33 |
problem unlock nokia 5200 with bb5 box | HADRIAN0141 | Nokia Base Band 5 ( BB-5 ) | 2 | 08-25-2008 20:53 |
www.bb5box.org | grosis | BB5BOX | 2 | 04-11-2008 17:59 |
WWW.BB5BOX.org does not connect in China? How renews BB5BOX? | shumrtong | BB5BOX | 1 | 11-12-2007 14:47 |
Having problems with box so trying on different pc but wont connect to www.bb5box.org | pearsonjohnboy | BB5BOX | 2 | 10-25-2007 10:25 |
