c7-broken display nokia c7 broken display after unlock key in the side..if you power on the mobile lcd display works fine but after it will lock and u will unlock sometimes it will be broken display..does anyone here have an idea?tnx |
Brother as i understand when you phone on stand by mode then u unlock from side key then its not come clear its color fake and like broken display, so u need to be change the display (LCD). |
yah u are right brother but it is not LCD problem i think coz i already replace 3 LCD and its still thesame problem |
Ok then change the complete first panel or strip, If same then u must reheat the D1400 Image processor. Post result. |
ok brother ill try to reheat that part,ill post the result later.. |
bother thesame problem finish reheat i even move d ic a little,,do i need to replace this? |
Brother before change it must check the lcd strip connector resold it if same then must change it - Post result.. |
