10-31-2011, 16:03 | #1 (permalink) |
Banned Join Date: Aug 2011
Member: 1638155 Status: Offline Thanks Meter: 5 | can i use any nokia part < transister ic > as the volatege regulater |
The Following 2 Users Say Thank You to gsmdon420 For This Useful Post: |
10-31-2011, 19:20 | #4 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: Punjab, Pakistan Age: 38
Member: 264520 Status: Offline Thanks Meter: 61 | Quote:
i've a transistor regulation circuit but we can't use on mobile pcb cause a tight area... So plz use Big nokia UEM Resitor near by 1100UEM, 1200-08 1650 UEM, etc and a single diode in series...in this case Resistor work as regulator and load Resistor.... ( this's a not 100% regulator alternate but some thing is batter then nothing) check attachment if u can understand schematic diagram... | |
The Following User Says Thank You to asrar For This Useful Post: |
11-01-2011, 16:34 | #5 (permalink) | |
Member: 1638155 Status: Offline Thanks Meter: 5 | Quote:
thanks sir for intrusting information............... sir if u found any small size regulator in future plz inform me.again thanks.......... | |
11-01-2011, 16:41 | #6 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,772 | Quote:
thanks sir i also learn more about this.thanks for ur hard work. | |
11-01-2011, 21:13 | #7 (permalink) | |
Junior Member Join Date: Apr 2006 Location: wahcantt rawalpindi pakistan
Member: 266405 Status: Offline Thanks Meter: 64 | nokia LDO regulator Quote:
brother u can take out 2.8volt regulator from 3100 pcb and use it where u need 2.8v like vmmc vcam i used in to many mobile and its easy to jumper because its not BGA I mean its 5 leg ic and this ic is also swich able by enable pin. i hope its help other. shahid aleem | |
The Following 2 Users Say Thank You to zaki537 For This Useful Post: |
11-02-2011, 19:35 | #8 (permalink) | |
Member: 1638155 Status: Offline Thanks Meter: 5 | Is it sir??????????????? Quote:
IS IT SIR ?????????????? | |
11-02-2011, 21:48 | #9 (permalink) |
Member: 266405 Status: Offline Thanks Meter: 64 | yes this one also this ic is available in 6100 7210 and other old model. pin detail u see in 3100 schematic or ic data sheet from alldatasheet web LP3985 pdf, LP3985 description, LP3985 datasheets, LP3985 view ::: ALLDATASHEET ::: also u can take out other LDO like 2.8v 1.8v 2.5v from chinese mobile and samsung mobile like e250 lcd board lg kg195 etc |
The Following 3 Users Say Thank You to zaki537 For This Useful Post: |
11-03-2011, 12:50 | #10 (permalink) |
Member: 264520 Status: Offline Thanks Meter: 61 | @gsmdon420 if u need regulator for charging purpose then @zaki537 nokia 3100 regulator is usless for u...but it's usefull for many other situtations... i've an one more trick to solve charging prob...this is old but gold.... 1. remove FUSE from phone and make a jumper batween chargin + to battery +.. 2. open charger and put 4.5v or 5v regulator in ur charger. u can use 7805 in charger... it's a very useful in any charging problem... and now you just press THANKS Micro |
11-03-2011, 18:21 | #11 (permalink) | |
thganks for reply sir but what use off this 3100 part ?plz tell us | |
11-04-2011, 14:10 | #12 (permalink) | |
i can't explain by example... it's a very useful and easy for advance engineers... click on pic Micro | |
The Following 4 Users Say Thank You to asrar For This Useful Post: |
11-17-2011, 17:41 | #13 (permalink) | |
Banned Join Date: Mar 2011
Member: 1543138 Status: Offline Thanks Meter: 21 | Quote:
thank you sir for very nice information............................... can you explain any part of nokia1100 nokia2600 or nokia3310 ? | |
The Following User Says Thank You to SHiVA_MOBiLE_CARE For This Useful Post: |
11-29-2011, 12:52 | #14 (permalink) | |
Member: 264520 Status: Offline Thanks Meter: 61 | 1200,1208 "No LCD" solution with 2.8v Regulator Quote:
Also use in ( 1200,1208 "No LCD" problem) Micro | |
11-29-2011, 13:16 | #15 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | hi, feeding charging input line directly to battery is not a charging solution in fone . if we do so ...... how battery temperature is maintained ? what is the role of BSI in this ? how current being regulated in accordance with battery temp ? is the set indicate charging ? if the thread starter needs a regulator for input circuit for protecting the input voltage , just use smd type 5 volt regulator, which is available in elctronix shops.(like 7805) or you can relay on series voltage regulator. u can fix voltage by choosing the brake down voltage of ZENER diode.and can control by current rating capacity of the transistor which is in series to the load. I just mentioned some facts, not blind ready made shortcuts. regards, NEIL |
