01-07-2011, 04:11 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::can someone experience reballing double ic of 7230 and x3::.. please share here bcoz i didnt find stencil for this double ic |
11-23-2011, 19:35 | #8 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | Dear it's not easy and it's not difficult. just use ur concentration i had made double ic this is the procejure -remove 1st ic and then remove 2nd ic and clean board from solder - then also clean ic ball from solder and 2nd ic also clean from solder both side be sure that both ic and board clean from solder and no balls remain on component then take ic plate with BGA paste and make re-ball on both ic through ic plate. remember that don't make re-ball on 2nd ic upper side because when u put 1st ic on 2nd ic then it can't be proper adjust , same like mother board only make re-ball on 1st ic and 2nd ic downside. that's it if any problem then you can reply here. |
11-23-2011, 19:47 | #9 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | For me no need of any kind of BGA stencil http://forum.gsmhosting.com/vbb/f148...g-way-1346110/ |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
