07-30-2008, 18:50 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: india
Member: 572872 Status: Offline Thanks Meter: 21 | charger not supported .......... I Want To Know Is There Any Perfect Or Last Solution For ''charger Not Supported '. After Replacing Bsi Components & Resistance Below Sim Tray , If Problem Still Remain Same , Can This Problem Solved By Changing 'thavo' Or 'retu' ? Is There Any Body Who Has Solved This Problem By Changing Thavo Or Retu ? Please Guide Me............... |
07-30-2008, 18:56 | #2 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 390359 Status: Offline Thanks Meter: 30 | for dct4 wd2 bb5 series charging problem soved by writing pm. if output voltage is correct (3.5-3.7volt) probably you have pm problem. in bb5 series charging ic is tahvo. but after unlock sometimes pm damages. you have to write modified pm for solution. output voltage is not in 3.5-3.7volt you should look first 47k resistor and other components. |
6110 navigator not charging / charger not supported solution tested .. 6110n | basilbaby | Nokia Hardware & Hardware Repair | 1 | 02-12-2009 05:46 |
2630 showing charger not supported when u insert the original charger | GOODNESS | Nokia Hardware & Hardware Repair | 5 | 12-11-2008 12:33 |
nokia 6131 when charge show charger not supported.pls help | austinchan | Nokia Hardware & Hardware Repair | 2 | 01-17-2008 15:34 |
6151 not charger not supported | point0 | Nokia Hardware & Hardware Repair | 1 | 11-13-2007 08:15 |
6233 Charger not supported | geosan1638 | Nokia Hardware & Hardware Repair | 0 | 09-26-2006 21:53 |
